Making a box in sheet metal... Why won't it work??!
I'm trying to make a simple box using the Solidworks sheet metal feature using flanges. I want all the surfaces to align perfectly but when I try and do the final surface it returns an error, even though it looks fine.
Can anyone take a look at my model and tell what the bloody hell is going wrong?
Thanks...
SolidworksParts And Features
Answers 6
IM
IM 2015-03-22 Best Answer
Intersecting
Have a look at the modified part, without errors. Just left gaps small gaps 0,01.
But edge flange 7 was way off.
comment imagecomment image
IM
IM 2015-03-22
Another version of edge flange 7. At least you should get the drift.
SF
SF 2015-03-22
Hi Ingvar,
Do you know if there is anyway to make them align perfectly as I am going to be doing FEA tests on the model with the tabs glued.
Thanks
IM
IM 2015-03-22
I suppose you could do it your way.Right click the body in the cut list select "insert into new part". Open that one and do the FEA. there with no warnings Then you can always go back and change the original part and the body in the new part updates.
IM
IM 2015-03-22
Probably best to do the FEA with the sheet metal part as I suggested with gaps and make contact sets for the flanges and treat as shell (sheet metal). Or you could probably just do it with the warnings on. I would think it would be better to do treat it as shell with contact sets instead of trying to treat it as solid with perfectly align faces.
SF
SF 2015-03-24
Thank you, this has worked.
