Somehow I have lost the ability to use different values in
Equations for different configurations. Just the table no longer offers the opportunity.
I know that it is like this, when you haven`t make any configurations, but
I have some.
Does anyone could
help me with advice, why it happens and how to recover this opportunity?
Thanks in advance.
- P.S. SOLIDWORKSProfessional 2015 x64 Editon SP5.0
Well, once you add a configuration to a part, your manage equation box should have the configuration drop down for each line item in your global variables list.
This will appear when you click in the line. This drop down will allow you to change a value and then apply it to individual configurations or to all configurations.
Are you seeing this drop down?
Thanks, Dan,
this is the exact way how it looked a while ago, but now it is changed to:
OK, another question:
Did it suddenly disappear on this part? Or was it showing on another part and now isn't showing on this part?
The reason why I ask is this from the help files:
This test sample works fine for me. Assign property for each configuration as number and link it to global variable in equations.
Now your global variable is configurated.
What version of Windows OS are you running?
Windows 7 @ SWX 2014 SP5
Windows 7 Professional SP1 64-bit Operating System
Yes, it suddenly disappered for this part (file). For other parts (files) still everything is ok.
The easiest would be to just start all over again. Since it is not just the first time I encounter this problem, I would like to understand what is wrong to avoid this in the future.
