I am designing a solid to represent the interior of a swimming pool. The kidney shaped pool has a 42" wall all the way around. That is the shallow end depth. The deep end depth is about 8.5' and has a semi circular type shape with sloped walls coming in from the sides and a straight line edge where the shallow end finishes. I'm trying to extrude a loft to form the solid but it doesn't seem to like having the two profiles with a shared edge (ie. where the shallow end drops off on a ramp toward the deep end. Help!
Here is the part...
SolidworksParts And Features
I think you should just loft between the areas excluding the common edge. I couldn't get a solid loft to work but the surface loft worked. Then I deleted the pool bottom where it should be deeper and all that's left is to fill in the open surface. But that is turning out to be tricky. I don't have time to keep working on it but maybe this will point you in the right direction.
Try Boundary. That being said, your guide curves are problematic.
See attached.
