Hello!
I'm trying to write a macro that makes a guiding hole in every end/start point of the bend lines in a sheet metal component. But i'm stuck with this code and can't make it.
Public Sub main()
Dim swPartDoc As SldWorks.ModelDoc2
Dim swFeature As SldWorks.Feature
Dim swSubFeature As SldWorks.Feature
Dim vSkSegArr As Variant
Dim vSkSeg As Variant
Dim swSkSeg As SldWorks.SketchSegment
Dim swSkLine As SldWorks.SketchLine
Set swPartDoc = swApp.ActiveDoc
Set swFeature = swPartDoc.FirstFeature
While Not swFeature Is Nothing
Select Case swFeature.GetTypeName2
Case "FlatPattern"
Set swSubFeature = swFeature.GetFirstSubFeature
While Not swSubFeature Is Nothing
If swSubFeature.Name Like "*Curva-Linhas*" Then
Dim swSketch As Sketch
Set swSketch = swSubFeature.GetSpecificFeature2
vSkSegArr = swSketch.GetSketchSegments
For Each vSkSeg In vSkSegArr
Set swSkSeg = vSkSeg
Select Case swSkSeg.GetType
Case swSketchLINE
Set swSkLine = swSkSeg
ProcessSketchLine swApp, swPartDoc, swSketch, swSkLine
End Select
Next vSkSeg
End If
Set swSubFeature = swSubFeature.GetNextSubFeature
Wend
End Select
Set swFeature = swFeature.GetNextFeature()
Wend
End Sub
Private Sub ProcessSketchLine(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, swSketch As SldWorks.Sketch, swSkLine As SldWorks.SketchLine)
Dim swStartPt As SldWorks.SketchPoint
Dim swEndPt As SldWorks.SketchPoint
Dim swStartModPt As SldWorks.MathPoint
Dim swEndModPt As SldWorks.MathPoint
Dim swFeatMgr As SldWorks.FeatureManager
Dim swFeat As SldWorks.Feature
Dim swWizHole As SldWorks.WizardHoleFeatureData2
Set swFeatMgr = swModel.FeatureManager
Set swStartPt = swSkLine.GetStartPoint2
Set swEndPt = swSkLine.GetEndPoint2
Set swFeat = swFeatMgr.HoleWizard(swWzdHole, _
swStandardAnsiMetric, _
swStandardAnsiMetricSocketHeadCapScrew, _
"M2.0", _
swEndCondThroughAll, _
2, _
2, _
swStartPt, _
swEndPt, False, False, False, False, False, False, False, False, False, False)
End Sub
SolidworksApi macros
