I have a part I'm detailing which has a 4-40 tapped hole in it.
I insert a Hole Callout annotation, and for the tap drill diameter (
I have checked the leading zero option in tools, options, document properties, dimensions. It is set to removed. All the other dimensions have the leading zero removed, just not this hole callout.
Any ideas??? Thx
Randy,
I can't tell you what you're getting wrong. All I can tell you is that the setting is there somewhere, because I'm still getting .089 as expected. SW11 SP3.0EV.
Do you use any non-ANSI standard settings? If not, switch away to ISO, then back to ANSI, and see if that fixes it.
Thanks All, we found the issue here.
The drawing properties are set correct. It turns out that the model properties are not. Randy had used a standard template to create a model which he then copied that model to use for another design so the incorrect settings came with it.
It's all good.
Once again, it was the leading zero settings within the model, not the drawing.
Randy
I believe this is a bug that they are working on (SPR 591053).
To work around the issue do the following:
1. Add the hole callout
2. Set your LEADING ZEROS option (these steps can be done in either order)
3. Click on the hole callout
4. Over in the property manager, under STYLE, click the first icon. It should be called "Apply the default attributes to the selected...."
This seemed to force the hole callout to follow the leading zero option.
SolidWorks 2012 SP3.0
Hope this helps,
~Toby Schnaars
