Issues with Save when attempting to save a newly created document.
Hello, I am relatively new to macros and have been trying to create a slightly complex macro that:
1. Updates custom fields of an open part depending on whether they exist, and what value they have.
2. Opens the drawing for said part and
  • If it exists:
    Updates the drawing template based on the sheet name, removes the BOM and saves the changes.
  • If it doesn't exist:
    Creates a new drawing based on a drawing template, it inserts the part into some predefined views and saves the newly created drawing.
I have no issues with this macro if the drawing already exists. However, if the drawing does not exist it is showing me an error and is not saving the newly created document. I have tried to use SaveAs3 as well as Save3 but I can't seem to get it working.
Thank you in advance, any help is much appreciated.
The macro:
Option Explicit
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swCustPropMgr As SldWorks.CustomPropertyManager
Sub main()
    'Declare loval variables for this sub-routine
    Dim lErrors As Long
    Dim lWarnings As Long
    Dim lConfResponse As Long
    Dim bForceRebuild As Boolean
    Dim bQuietSaveResult As Boolean
    Dim sVal As String
    Dim lRetCode As Long                'For swCustPropMgr.Get6
    Dim sResolvedVal As String          'For custom property values
    Dim bWasResolved As Boolean         'For custom property Get6 method
    Dim bLinkToProp As Boolean          'For custom property Get6 method
    Dim swDrawingDoc As SldWorks.DrawingDoc     'Declare DrawingDoc for activation !!!
    'Get the Solidworks application object
    'Get the active Solidworks document
    Set swModel = swApp.ActiveDoc
    '-----  Initial Checks  -----
    'Check that a document is open
    If swModel Is Nothing Then
        'swApp.SendMsgToUser2 "No solidworks document is open. Please open a Part document.", swMbStop, swMbOk
        Debug.Print "No SolidWorks document is open.Exiting." '!!!
        Exit Sub
    End If
    'Check that the document open is a part
    If swModel.GetType() <> swDocumentTypes_e.swDocPART Then 'And swModel.GetType() <> swDocumentTypes_e.swDocASSEMBLY
        'swApp.SendMsgToUser2 "The active document is not a Part. Please open a Part to continue.", swMbStop, swMbOk
        Debug.Print "the active document is not a Part. Exiting." '!!!
        Exit Sub
    End If
    'Get the ModelDocExtension and CustomPropertyManager
    Set swModelDocExt = swModel.Extension
    Set swCustPropMgr = swModelDocExt.CustomPropertyManager("") 'Empty string to get a document-level property
    '-----  Ask for confirmation that the part wants to be updated  -----
    'lConfResponse = swApp.SendMsgToUser2("Do you want to continue updating the current Part and its corresponding drawing to the latest Template?", swMbQuestion, swMbYesNo)
    'If lConfResponse = swMbHitNo Then
        'swApp.SendMsgToUser2 "Update cancelled.", swMbInformation, swMbOk
        'Exit Sub
    'End If
    '-----  Update Custom Properties    -----
    'Ensure custom properties exist and add them if new
    Call EnsureCustomProperty("PROFILING", swCustomInfoText, swCustPropMgr)
    Call EnsureCustomProperty("HEAT TREATMENT", swCustomInfoText, swCustPropMgr)
    Call EnsureCustomProperty("SURFACE COATING", swCustomInfoText, swCustPropMgr)
    'Handle REVISION property
    'Check if the property exists
    lRetCode = swCustPropMgr.Get6("REVISION", False, sVal, sResolvedVal, bWasResolved, bLinkToProp)
    If lRetCode = swCustomInfoGetResult_e.swCustomInfoGetResult_NotPresent Then
        'Property does not exist, add it.
        swCustPropMgr.Add3 "REVISION", swCustomInfoText, "0", swCustomPropertyOnlyIfNew
        Debug.Print "REVISION added successfully."
    ElseIf lRetCode = swCustomInfoGetResult_e.swCustomInfoGetResult_ResolvedValue Then
        If sVal = "" Then
        'Property already exists but is blank. Set to default value "0".
        swCustPropMgr.Set2 "REVISION", "0"
        Debug.Print "REVISION was blank, successfully set to default (0)."
        Else
        'Property already exists and has a value. Do nothing
        Debug.Print "REVISION verified."
        End If
    Else
        'Some other error ocurred during Get6
        Debug.Print "Error checking Custom Property: 'REVISION'. Return Code: " & lRetCode
        'swApp.SendMsgToUser2 "Error checking Custom Property 'REVISION'. Return Code: " & lRetCode, swMbStop, swMbOk
    End If
    'Handle PROJECT NAME property
    Dim sTargetValueProjName As String
    sTargetValueProjName = "Ask Customer: <LINE ID> <OEM ID> <MACHINE NAME>"
    lRetCode = swCustPropMgr.Get6("PROJECT NAME", False, "", sResolvedVal, bWasResolved, bLinkToProp)
        'Property exists. Check its value.
            If Trim(sResolvedVal) = sTargetValueProjName Then
                swCustPropMgr.Set2 "PROJECT NAME", "" ' Set to blank
                Debug.Print "PROJECT NAME was 'Ask Customer: <LINE ID> <OEM ID> <MACHINE NAME>', set to blank." '!!!
            Else '!!!
                Debug.Print "PROJECT NAME verified." '!!!
            End If
            'Debug.Print "PROJECT NAME updated successfully." '!!! commented out
        ElseIf lRetCode = swCustomInfoGetResult_e.swCustomInfoGetResult_NotPresent Then '!!!
            Debug.Print " PROJECT NAME property not present. Skipping value check." '!!!
        Else
            Debug.Print "Error checking Custom Property 'PROJECT NAME'. Error Code: " & lRetCode
            'swApp.SendMsgToUser2 "Error checking Custom Property 'PROJECT NAME'. Error Code: " & lRetCode, swMbStop, swMbOk
            Exit Sub
        End If
    '-----  Finalize Part Updates   -----
    'Force rebuild
    bForceRebuild = swModelDocExt.EditRebuildAll
    Debug.Print "Part rebuilt: " & bForceRebuild '!!!
    'Isometric Zoom to Fit
    swModel.ShowNamedView2 "*Isometric", -1
    swModel.ViewZoomtofit2
    Debug.Print "Part view set to Isometric and Zooom to Fit." '!!!
    'Quiet Save the part
    bQuietSaveResult = swModel.Save3(swSaveAsOptions_e.swSaveAsOptions_Silent, lErrors, lWarnings)
        If bQuietSaveResult Then
            Debug.Print "Part update saved successfully."
        Else
            Debug.Print "Part update not saved."
        End If
    '-----  Call the Drawing Sub-Routine    -----
    Call OpenOrCreateDrawing
    'Ensure the drawing is the active document before updating sheet formats !!!
    Set swDrawingDoc = swApp.ActiveDoc '!!!
    If Not swDrawingDoc Is Nothing And swDrawingDoc.GetType = swDocumentTypes_e.swDocDRAWING Then '!!!
        Debug.Print "Activating drawing: " & swDrawingDoc.GetTitle '!!!
        swApp.ActivateDoc3 swDrawingDoc.GetTitle, True, swRebuildActiveDoc, lErrors '!!!
    Else '!!!
        Debug.Print "No drawing document active. Cannot proceed with sheet format updates." '!!!
        Exit Sub 'Exit sub if drawing is not active !!!
    End If '!!!
    '-----  Call the Update Sheet Format Sub-Routines
    Call UpdateSheetFormatPREC
    Call UpdateSheetFormatCUST
    'Final save
    Dim swActiveDoc As SldWorks.ModelDoc2
    Dim lFinalErrors As Long
    Dim lFinalWarnings As Long
    Dim bFinalSaveResult As Boolean
    Set swActiveDoc = swApp.ActiveDoc
    If Not swActiveDoc Is Nothing Then
        If swActiveDoc.GetType = swDocumentTypes_e.swDocDRAWING Then
            bFinalSaveResult = swActiveDoc.Save3(swSaveAsOptions_e.swSaveAsOptions_Silent, lFinalErrors, lFinalWarnings)
            If Not bFinalSaveResult Then
                Debug.Print "Final save of drawing failed. Errors: " & lFinalErrors & ", Warnings: " & lFinalWarnings
            Else
                Debug.Print "Drawing saved successfully after all operations."
            End If
        End If
    End If
    'Re-activate the part if it's not the active document and save it again !!!
    If swApp.ActiveDoc.GetPathName <> swModel.GetPathName Then '!!!
        swApp.ActivateDoc3 swModel.GetTitle, True, swRebuildActiveDoc, lErrors '!!!
    End If '!!!
    If Not bQuietSaveResult Then
        Debug.Print "Final save of part failed. Errors: " & lErrors & ", Warnings: " & lWarnings
    Else
        Debug.Print "Part saved successfully after all operations."
    End If
End Sub
'-----  Helper Function to Ensure Custom Property Exists    -----
'This function checks if a custom property exists. If it does not, it gets added.
'It does not modify an existing property's value.
Function EnsureCustomProperty(sPropName As String, lPropType As swCustomInfoType_e, swPropMgr As SldWorks.CustomPropertyManager, Optional sDefaultValue As String = "") As Boolean
    Dim sVal As String
    Dim lAddResult As Long
    lRetCode = swPropMgr.Get6(sPropName, False, sVal, sResolvedVal, bWasResolved, bLinkToProp)
        lAddResult = swPropMgr.Add3(sPropName, lPropType, sDefaultValue, swCustomPropertyOnlyIfNew)
        If lAddResult = swCustomInfoAddResult_e.swCustomInfoAddResult_AddedOrChanged Then
            EnsureCustomProperty = True
        Else
            EnsureCustomProperty = False
        End If
        Debug.Print "Custom property: " & sPropName & " successfully added."
        'Property already exists, do nothing.
        Debug.Print "Custom property: " & sPropName & " already existed."
    Else
        Debug.Print "Error checking Custom Property: " & sPropName & "'. Return Code: " & lRetCode
        'swApp.SendMsgToUser2 "Error checking Custom Property '" & sPropName & "'. Return Code: " & lRetCode, swMbStop, swMbOk
    End If
End Function
'-----  Sub-Routine to Open or Create Drawing   ----
Sub OpenOrCreateDrawing()
    'Declare lcoal variables for this sub-routine
    Dim swPart As SldWorks.PartDoc
    Dim swDrawing As SldWorks.DrawingDoc
    Dim sPartPath As String
    Dim sDrawingPath As String
    Dim lErrors As Long
    Dim bInsertResult As Boolean
    Dim bQuietSaveDrwResult As Boolean
    '-----  CONFIGURATION   -----
    'Set the path to drawing template & predefined views
    Const DRAWING_TEMPLATE_PATH As String = "C:\\Users\\DrawingOffice\\Desktop\\SOLIDWORKS TEMPLATES\\Drawing and Part Templates\\A3 UPDATED CATALOGUE PART DRAWING.DRWDOT"
    '-----  Ensure swApp and Model are already set from the main sub    -----
    If swApp Is Nothing Then
        'swApp.SendMsgToUser2 "Application object not initialised. Cannot open or create drawing.", swMbWarning, swMbOk
        Debug.Print "Application object not initialised. Cannot open or create drawing."
        Exit Sub
    End If
        'swApp.SendMsgToUser2 "Model object not initialised. Cannot open or create drawing.", swMbStop, swMbOk
        Debug.Print "Model object not initialised. Cannot open or create drawing."
        Exit Sub
    End If
    'Cast to PartDoc for part-specific properties
    Set swPart = swModel
    'Get the Part Document's full path
    sPartPath = swPart.GetPathName()
    If sPartPath = "" Then
        'swApp.SendMsgToUser2 "The active part has not been saved yet. Please save the part before creating a drawing.", swMbStop, swMbOk
        Debug.Print "The active part has not been saved yet. The part needs to be saved before proceeding." '!!!
        Exit Sub
    End If
    'Construct the potential drawing path
    'Assumes the drawing will be in the same folder, and have the same name.
    sDrawingPath = Left(sPartPath, InStrRev(sPartPath, ".")) & "SLDDRW"
    Debug.Print "Attempting to open/create drawing at " & sDrawingPath
    'Check if the drawing file exists
    If Dir(sDrawingPath) <> "" Then
        'Drawing exists, try to open it
        Set swDrawing = swApp.OpenDoc6(sDrawingPath, swDocumentTypes_e.swDocDRAWING, swOpenDocOptions_e.swOpenDocOptions_LoadModel, "", lErrors, lWarnings)
        Debug.Print "Drawing found attempting to open it."
        If Not swDrawing Is Nothing Then
            'Rebuild/update drawing views
            swDrawing.ForceRebuild
            Debug.Print "Drawing successfully opened."
        Else
            'swApp.SendMsgToUser2 "Failed to open drawing '" & Mid(sDrawingPath, InStrRev(sDrawingPath, "\\") + 1) & "'. SolidWorks Errors: " & lErrors & "Warnings: " & lWarnings, swMbStop, swMbOk
            Debug.Print "OpenDoc6 failed for drawing: " & sDrawingPath
            Debug.Print "OpenDoc6 Errors: " & lErrors & ", Warnings: " & lWarnings
        End If
    Else
        Dim nCreateDrawing As Integer
        'Drawing does not exist, ask if a new one should be created
        'nCreateDrawing = swApp.SendMsgToUser2("Drawing not found for '" & Mid(sPartPath, InStrRev(sPartPath, "\\") + 1) & "'. Create a new drawing?", swMbInformation, swMbYesNo)
        'Create new drawing from template
        'If nCreateDrawing = swMessageBoxResult_e.swMbHitNo Then
            'Exit Sub
        'Else
            Set swDrawing = swApp.NewDocument(DRAWING_TEMPLATE_PATH, 0, 0, 0)
            Debug.Print "Drawing not found. New drawing successfully created."
                    ' Activate and rebuild the new drawing document
                    swApp.ActivateDoc3 swDrawing.GetTitle, True, swRebuildActiveDoc, lErrors
                    'Insert model in predefined views
                    bInsertResult = swDrawing.InsertModelInPredefinedView(sPartPath)
                    Debug.Print "Inserting model in predefined views. Result: " & bInsertResult
                    'Insert dimensions
                    swDrawing.InsertModelAnnotations3 swImportModelItemsFromEntireModel, swInsertDimensionsMarkedForDrawing, True, True, True, True
                    Debug.Print "Inserting model dimensions."
                    'Save the newly created drawing !!!
                    bQuietSaveDrwResult = swModel.Save3(swSaveAsOptions_Silent, lErrors, lWarnings)
                    If Not bQuietSaveDrwResult Then '!!!
                        Debug.Print "Failed to save new drawing '" & Mid(sDrawingPath, InStrRev(sDrawingPath, "\\") + 1) & "'/Errors: " & lErrors; ". Warnings: " & lWarnings & "." '!!!
                    Else '!!!
                        Debug.Print "New drawing saved successfully to: " & sDrawingPath '!!!
                    End If '!!!
                Else
                    Debug.Print "Failed to create new drawing from template: " & DRAWING_TEMPLATE_PATH
                    Exit Sub
                End If
        'End If
    End If
    Call ForceRebuildAllDrawings
    'The 3 lines bellow were commented out as they were flagged up as problematic. The drawing is now saved when created !!!
    'If Not swDrawing Is Nothing Then
    '   swModel.Extension.SaveAs sDrawingPath, swSaveAsCurrentVersion, swSaveAsOptions_Silent, Nothing, Empty, Empty
    'End If
End Sub
Sub UpdateSheetFormatPREC()
Dim swSheet As SldWorks.sheet
Dim vSheetName As Variant
Dim i As Long
Dim sSheetFormatPath As String
Dim sCurrentSheet As String
Dim bRet As Boolean
Dim lErrors As Long
Dim swFeat As SldWorks.Feature
'-----  Delete BOM  -----
'Set swFeat = swModel.FirstFeature modved to later on!!!
swModel.ClearSelection2 True
'Only attempt to delete BOM if the active document is a drawing
If swModel.GetType() = swDocumentTypes_e.swDocDRAWING Then '!!!
    Set swDrawing = swModel '!!!
    Set swFeat = swDrawing.FirstFeature ' Iterate features of the drawing !!!
    While Not swFeat Is Nothing
        If "BomFeat" = swFeat.GetTypeName Then
            Debug.Print "Attempting to delete BOM: " & swFeat.Name '!!!
            swFeat.Select2 True, 0
            swDrawing.Extension.DeleteSelection2 swDeleteSelectionOptions_e.swDelete_Absorbed '!!!
            Debug.Print "BOM deleted successfully." '!!!
        End If
        Set swFeat = swFeat.GetNextFeature
    Wend
Else '!!!
    Debug.Print "Active document is not a drawing. Skipping BOM deletion." '!!!
End If '!!!
'swModel.Extension.DeleteSelection2 swDeleteSelectionOptions_e.swDelete_Absorbed
Set swDrawing = swApp.ActiveDoc
sSheetFormatPath = "C:\\Users\\DrawingOffice\\Desktop\\SOLIDWORKS TEMPLATES\\Drawing and Part Templates\\A3 CATALOGUE PART DRAWING UPDATED.slddrt" '
    If swDrawing.GetType = swDocumentTypes_e.swDocDRAWING Then
        vSheetName = swDrawing.GetSheetNames
        If Not IsEmpty(vSheetName) Then
            For i = 0 To UBound(vSheetName)
                Set swSheet = swDrawing.sheet(vSheetName(i))
                    If swSheet.GetName = "Sheet1" Then
                        sCurrentSheet = swDrawing.ActivateSheet("Sheet1")
                        Debug.Print "Activating Sheet1 and updating format." '!!!
                        bRet = swDrawing.SetupSheet6(swSheet.GetName, swDwgPaperSizes_e.swDwgPapersUserDefined, swDwgTemplates_e.swDwgTemplateCustom, 1, 1, True, sSheetFormatPath, 0.42, 0.297, "Default", True, 0, 0, 0, 0, 0, 0)
                        Debug.Print "SetupSheet6 for Sheet1 result: " & bRet '!!!
                    ElseIf swSheet.GetName = "PRECISION" Then
                        sCurrentSheet = swDrawing.ActivateSheet("PRECISION")
                        Debug.Print "Activating PRECISION sheet and updating format." '!!!
                        Debug.Print "SetupSheet6 for PRECISION result: " & bRet '!!!
                    End If
            Next i
        Else '!!!
            Debug.Print "No sheets found in the drawing for PRECISION update." '!!!
        End If
    Else '!!!
        Debug.Print "Active document is not a drawing. Cannot update sheet format for PRECISION." '!!!
        Exit Sub '!!!
    End If
Else '!!!
    Debug.Print "No active drawing document. Cannot update sheet format for PRECISION." '!!!
    Exit Sub '!!!
End If
        bQuietSaveDrwResult = swDrawing.Save3(swSaveAsOptions_Silent, lErrors, lWarnings)
            Debug.Print "Failed to save drawing after PRECISION sheet format update. Errors: " & lErrors & ", Warnings: " & lWarnings & "."
        Else
            Debug.Print "Drawing saved successfully after PRECISION sheet format update."
        End If
    Else
        Debug.Print "swDrawing object is Nothing at save point for PRECISION."
    End If
End Sub
Sub UpdateSheetFormatCUST()
Dim i As Long
Dim bRet As Boolean
Dim lErrors As Long
Dim sDrawingFileName As String
'Set swFeat = swModel.FirstFeature moved to later on
            Debug.Print "BOM deleted." '!!!!
        End If
    Wend
Else '!!!
End If '!!!
sSheetFormatPath = "C:\\Users\\DrawingOffice\\Desktop\\SOLIDWORKS TEMPLATES\\Drawing and Part Templates\\A3 CATALOGUE PART DRAWING UPDATED - CUSTOMER.slddrt" '
                    If swSheet.GetName = "Sheet2" Then
                        sCurrentSheet = swDrawing.ActivateSheet("Sheet2")
                        Debug.Print "Activating Sheet2 and updating format." '!!!
                        Debug.Print "SetupSheet6 for Sheet2 result: " & bRet '!!!
                    ElseIf swSheet.GetName = "CUSTOMER" Then
                        sCurrentSheet = swDrawing.ActivateSheet("CUSTOMER")
                        Debug.Print "Activating CUSTOMER sheet and updating format." '!!!
                        Debug.Print "SetupSheet6 for CUSTOMER result " & bRet '!!!
                    End If
            Next i
        Else
            Debug.Print "No sheets found in the drawing for CUSTOMER update."
        End If
    Else
        Debug.Print "Active document is not a drawing. Cannot update sheet format for CUSTOMER."
        Exit Sub
    End If
Else
    Debug.Print "No active drawing document. Cannot update sheet format for CUSTOMER."
    Exit Sub
End If
            Debug.Print "Failed to save drawing after CUSTOMER sheet format update. Errors: " & lErrors & ", Warnings: " & lWarnings & "."
        Else
            Debug.Print "Drawing saved successfully after CUSTOMER sheet format update."
        End If
    Else
        Debug.Print "swDrawing object is Nothing at save point for CUSTOMER."
    End If
End Sub
Sub ForceRebuildAllDrawings()
Dim vModels As Variant
Dim i As Long
Dim bRebuildResult As Boolean
vModels = swApp.GetDocuments
For i = LBound(vModels) To UBound(vModels)
    Set swModel = vModels(i)
    If Not swModel Is Nothing Then
        If swModel.GetType = swDocumentTypes_e.swDocDRAWING Then
            bRebuildResult = swModel.ForceRebuild3(True)
            Debug.Print "Rebuild drawing: " & swModel.GetTitle & ". Result: " & bRebuildResult '!!!
        End If
    End If
Next i
End Sub
Answers 2
JB
JB 2025-07-28
Thank you for posting your code!  However, there's a lot of code here.  We need to know (a)what is the error you are shown, and (b)which line out of all the above causes the error?
Otherwise, I recommend the approach of biting off little chunks that work and then working your way back to what doesn't.
For example, start with the minimum code to create a drawing from the currently active part file, and then save it.  The absolute minimum.  If that works, start adding in more of the actions that you want to do, little by little, in the simplest way you can, until you figure out what is introducing the error.
RA
RA 2026-04-11
Here's my program.  You will have to run it from the drawing.  And it also works for assemblies as well, provided you open the drawing first then run the program.  It will even replace a component within the assembly.  It helps if you watch the attached video file.  And the SSL / SSW / MATUSED data is being pulled from formula calculations, just an fyi....  Hope this helps.
- Apologies for the graphics of the video.  I re-recorded the video hoping for a better resolution, but for the most part, you can still see what's going on.
- Richard
' C:\Users\Rrodriguez\AppData\Local\Temp\swx28756\Macro1.swb - macro recorded on 12/29/23 by rrodriguez
Option Explicit
Dim swDraw As SldWorks.DrawingDoc
Dim i As Integer
Dim bRet As Boolean
Dim Part As Object
Dim boolstatus As Boolean
Dim longstatus As Long, longwarnings As Long
Dim OGPart As String
Dim MyFolder As String
Dim MyNewPN As String
Dim MyNewPart As String
Dim DataEntered As String
Dim Proceed As Integer
Dim InputLoop As Integer
Dim UpdateAnn As Integer
Dim X As Integer
Dim GetPropertyNames As Variant
Dim cpm As CustomPropertyManager
Dim swErrors As Long
Dim swWarnings As Long
Sub main()
If (swModel Is Nothing) Or (swModel.GetType <> swDocDRAWING) Then
  MsgBox "This program only works on drawings."
  Exit Sub
End If
Set swDraw = swModel
MyFolder = swModel.GetTitle
Set Part = swApp.ActivateDoc(MyFolder)
DataEntered = Left(MyFolder, InStrRev(MyFolder, "-") - 2) + "2"
' THIS PORTION REQUESTS THE USER TO INPUT INFO FOR NEW PART TO BE CREATED
OGPart = Left(swModel.GetTitle, InStrRev(swModel.GetTitle, "-") - 2)
Loop1:
MyNewPN = InputBox("Existing Part Number is as follows:" + Chr(10) + OGPart + Chr(10) + Chr(10) + _
                 "Enter new part number:", "FILE SAVE AS", DataEntered)
If MyNewPN = "" Then Exit Sub
MyNewPart = Left(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") - 1) + "\" + MyNewPN + ".SLDDRW"
Proceed = MsgBox("FROM:" & Chr(10) & Left(MyFolder, InStrRev(MyFolder, "-") - 2) & Chr(10) & Chr(10) _
      & "TO:" & Chr(10) & MyNewPN & Chr(10) & Chr(10) & Chr(10) & "Would you like to proceed?", vbYesNo, "THE NEW PART WILL BE CONVERTED")
If Proceed = vbNo Then
  InputLoop = MsgBox("Would you like to re-enter the Part Number information?", vbYesNo, "RE-ENTER DATA")
  If InputLoop = vbYes Then
      DataEntered = MyNewPN
      GoTo Loop1
  Else
      Exit Sub
  End If
Else
  Set swDrawing = swModel   '--> SAVES DRAWING AS NEW PART
  swDraw.ViewFullPage
  swModel.Extension.SaveAs MyNewPart, swSaveAsCurrentVersion, swSaveAsOptions_Silent, Nothing, swErrors, swWarnings
  boolstatus = Part.Save3(1, swErrors, swWarnings)
' THIS PORTION OF THE CODE OPENS & SAVES THE OG PART AS A NEW PART
  swApp.ActivateDoc2 OGPart, False, longstatus
  If swModel.GetType = swDocPART Then
      MyNewPart = MyNewPN + ".SLDPRT"
  Else
      MyNewPart = MyNewPN + ".SLDASM"
  End If
End If
' THIS PORTION OF THE CODE UPDATES THE FILE PROPERTIES OF THE NEW PART
Dim ConfigName As String
Dim CurrentMat As String
Dim CurrentMatPN As String
Dim CuPlating As Integer
Dim CurrentIni As String
Dim CurrentDBy As String
Dim CurrentDDt As String
Dim CurrentREV As String
Dim newDESC As String
Dim ChgExtInfo As Integer
ConfigName = swModel.ConfigurationManager.ActiveConfiguration.Name 'CONFIGNAME IS "DEFAULT" ON CONFIG SPECIFIC
swModel.DeleteCustomInfo2 "", "PART TYPE"
swModel.DeleteCustomInfo2 ConfigName, "PART TYPE"
swModel.DeleteCustomInfo2 "", "Weight"
swModel.DeleteCustomInfo2 "", "TOLERANCE"
Set cpm = swModel.Extension.CustomPropertyManager("")
CurrentMat = swModel.GetCustomInfoValue("", "Material")
CurrentMatPN = swModel.GetCustomInfoValue("", "MatPartNo")
CurrentIni = swModel.GetCustomInfoValue("", "Initials")
CurrentDBy = swModel.GetCustomInfoValue("", "DrawnBy")
CurrentDDt = swModel.GetCustomInfoValue("", "DrawnDate")
  If CurrentDDt = "" Then
  CurrentDDt = swModel.GetCustomInfoValue("", "DateDrawn")
  End If
CurrentREV = swModel.GetCustomInfoValue("", "REV")
newDESC = Right(MyNewPN, Len(MyNewPN) - InStr(MyNewPN, " "))
newDESC = Replace(newDESC, "w-", "w/")
newDESC = Replace(newDESC, "''", """")
newDESC = Replace(newDESC, "_1-4", "¼")
newDESC = Replace(newDESC, "_1-2", "½")
newDESC = Replace(newDESC, "_3-4", "¾")
cpm.Add3 "PartNo", swCustomInfoText, Left(MyNewPN, InStr(swModel.GetTitle, " ") - 1), 1
cpm.Add3 "Description", swCustomInfoText, newDESC, 1
 If swModel.GetType = swDocASSEMBLY Then GoTo Line20
cpm.Add3 "Material", swCustomInfoText, CurrentMat, 1
cpm.Add3 "MatPartNo", swCustomInfoText, CurrentMatPN, 1
  If Left(MyFolder, 5) = "18-80" Then
  cpm.Add3 "ShearSize", swCustomInfoText, """D1@Boss-Extrude1""", 1
  Else
  cpm.Add3 "ShearSize", swCustomInfoText, """SSL@PART.SLDPRT"" x ""SSW@PART.SLDPRT""", 1
  End If
cpm.Add3 "USAGE", swCustomInfoText, """MATUSED@PART.SLDPRT""", 1
Line20:
cpm.Add3 "Weight", swCustomInfoText, """SW-Mass"" LB", 1
' NEW BUILD OR KEEP THE EXISTING DATE / NAME?
ChgExtInfo = MsgBox("Will this be a new drawing?", vbYesNo, "NEW DRAWING?")
If ChgExtInfo = vbYes Then
  cpm.Add3 "DrawnBy", swCustomInfoText, "RICHARD RODRIGUEZ", 1
  cpm.Add3 "DateDrawn", swCustomInfoText, CStr(Format(Date, "MM/DD/YY")), 1
  cpm.Add3 "Initials", swCustomInfoText, "RR", 1
  cpm.Add3 "REV", swCustomInfoText, "A", 1
Else
  cpm.Add3 "DrawnBy", swCustomInfoText, CurrentDBy, 1
  cpm.Add3 "DateDrawn", swCustomInfoText, CurrentDDt, 1
  If CurrentIni <> "" Then cpm.Add3 "Initials", swCustomInfoText, CurrentIni, 1
  If CurrentREV = "" Then
  Else
      cpm.Add3 "REV", swCustomInfoText, CurrentREV, 1
  End If
End If
' REBUILDS & SAVES NEW PART
Set Part = swApp.ActiveDoc
Part.ShowNamedView2 "*Isometric", 7
Part.ViewZoomtofit2
boolstatus = Part.EditRebuild3()
MyNewPart = MyNewPN + ".SLDDRW"
Set Part = swApp.ActivateDoc(MyNewPart)
Dim swSheet As Sheet
vSheetName = swDraw.GetSheetNames  'Get the sheets in the drawing document
' DELETES REV INFO ON REVISION TABLE
      bRet = swDraw.ActivateSheet(vSheetName(i))
      Set swSheet = swDraw.Sheet(vSheetName(i)) 'swSheet = swDraw.GetCurrentSheet
      boolstatus = Part.Extension.SelectByID2("Sheet1", "SHEET", 0, 0, 0, False, 0, Nothing, 0)
      Part.EditTemplate
      Part.EditSketch
      boolstatus = Part.Extension.SketchBoxSelect(0.017, 0.023, 0, 0.155, 0.04, 0)
      Part.EditDelete
      Part.ClearSelection2 True
      boolstatus = Part.Extension.SelectByID2("Sheet Format1", "SHEET", 0, 0, 0, False, 0, Nothing, 0)
      Part.EditSheet
      Part.EditSketch
      Part.ViewZoomtofit2
  Next i
End If
bRet = swDraw.ActivateSheet(vSheetName(0)) 'Activates Sheet1
Part.EditSheet
Part.ViewZoomtofit2
End Sub
