I created a curve using the Curve Through XYZ Points feature. After creating the curve, I used the Convert Entities command to create a sketch. However, the resulting sketch does not match the original XYZ curve smoothly and does not follow the same geometry as the original curve.
I have attached the Reference IMAGE and the XYZ points file for your better understanding and further verification.
Thanks
Boopathi
I think the XYZ points file did not upload.
Right of the green "Answered" is a dropdown menu. On it, Edit will let you modify your OP, title and body, so you can drop in your point file. Zip it first and let the upload finish before you save your edits.
