We share files between physical plant locations and each of those locations has their own local server supporting SW. So far, it looks like common Property Template files between locations need to be referenced in the very same path at any location. (example: R:\\solidworks\\templates) Where "R:" represents a share from the local server. Is there a way to define a client environment variable as part of the path to property template files on the local server? (example: %SW_SERVER%\\solidworks\\templates)
SolidworksAdministration
You could create a folder on any drive and define it as a share drive. And then add your files to that location and map the path to that drive. Finally do the same on other plants. This way the files will have same reference path.
