Is it possible to replace a set of Metric Bolt added from tool box with Unified Standard Bolt?
Also inside which folder I can find Unified Standard thread in Tool Box?
SolidworksAssemblies
Answers 9
IW
IW 2015-07-07 Best Answer
Right click on the bolt you want to change & select "Replace Model" (you might have to expand the menu by clicking the v at the bottom)
JJ
JJ 2015-07-07
I could not find any replace component option when I right click.
Also please help me to find Unified Standard Stud (not Bolt) from tool box.
JJ
JJ 2015-07-07
Do we have Unified Standard Stud in Solidworkd Tool Box.?
JJ
JJ 2015-07-07
Thanks..... Replace component I am able to find out.........
BD
BD 2015-07-07
Yes, In the PEM Inch folder and in the sub-folder labeled studs.....If you are looking for a bolt, they are in the ANSI Inch folder.....
JS
JS 2015-07-07
A handy trick I have used is to insert a new fastener from toolbox with the style you want to change to. Then you can right click on it and open part. Now switch back to the assembly and do Replace Component on the old part and the new one will show up in the list of open documents. That way you don't have to browse for it.
JJ
JJ 2015-07-07
thanks..............
JJ
JJ 2015-07-07
Thanks for that but I am looking for the studs with out any head (Rod with full thread) and also size of 1.1/4'' [25.4mm+25.4/4mm(to make the value more clear)]
BD
BD 2015-07-07
I haven't noticed that component in toolbox.  You could find a bolt with the correct thread, longer that you need, save it as a new component and cut off the head....
