Is it possible to "dissolve" a sub-assembly within an assembly
Hi!
I have a sub-assembly inside an assembly, and I created an explodeview and want to put balloons to all parts of the sub-assembly. Butit allowed only put one and the same number to every part withinthis sub-assembly.
So, is there any way to "dissolve" this sub-assembly to haveseparate parts, that I will be able to assign balloons to each one?
Thank you in advance,
Mark
SolidworksAssemblies
Answers 3
CC
CC 2008-11-13 Best Answer
Yes, right click on the assembly in the feature manager tree,and select "dissolve sub-assembly". How's that for straightforward.
TP
TP 2008-11-13
If you are only concerned about BOM numbers you should notdissolve your assembly. Instead change the BOM type to "Parts only"and make sure your view is linked to your BOM by RMC the view goingto properties and creating the link. All parts will now have theirown number.
SF
SF 2008-11-13
Thank you very much for your help!
Mark
