I am trying to run SW17 on my new surface pro. It has Intel Iris Plus 640 GPU. I have been having issues with the OpenGL. I saw in a few forums where people would go in and change the regedit for solidworks hardware. My registry only has the Intel Iris Pro listed, not the Intel Iris Plus. Does anybody have any suggestions on how to get this resolved? or I am going to have to wait for a software or hardware update?
SolidworksGeneral
I have a Dell XPS 13 and it too has the "Intel Iris Plus 640".
It is unusable when drawing some outlines. (I understand this is an OpenGL problem). I'm also looking for a solution.
OK by doing more Googling ... the work around is to use regedit to add a Key in the registry:
Add the key "Intel(R) Iris(TM) Plus Graphics 640" under
"HKEY_CURRENT_USER\Software\SOLIDWORKS\SOLIDWORKS 2017\Performance\Graphics\Hardware\Intel\"
Under this key add a DWORD with the name "Workarounds" and give it a hex value of 10000009
This does not enable "realview".
I tried adding a workaround in the directory
"HKEY_CURRENT_USER\Software\SOLIDWORKS\SOLIDWORKS 2017\Performance\Graphics\Hardware\Gl2Shares\Intel\Intel(R) Iris(TM) Plus Graphics 640" but to no efffect. I see the other Intel devices listed have another key under the card name ... perhaps this is what is needed although I don't know what is the correct naming convention.
I have done the "Realview Hack" to my system. When I did it, I had to try several different values before I found one that actually worked. Also note the hack does not work with every card........
My only suggestion would be more google research and see if others suggest a different value by chance.
Dave.
I tried this and open gl is still greyed out know of any other solutions
Can you recommend values to try and could a value potentially mess up any hardware?
40408 worked for me.........
Dave.
Thanks man; this made me rethink my decision to stray from a history of using Surface Pros for my SW work. I really wanted a machine that could handle RealView for flashy quick presentations. I struggled along with Surface Pros 1 thru 4 (Which all have Intel HDs), and with the new 2017 version not having a beefy GPU, I gave up. I got an HP Spectre 360x, which is fine, but it's bulky and gets hot...it's really a pain in the ass, and quite honesty, it takes the fun out of work. My Surface Pro 4 has an Iris 540, so I figured I'd give the registry tweek a go...lo-and-behold, it WORKED! I ended up using 80408; I've attached link to a Surface Pro 4 i7 registry file for SW2018 for anyone who needs it. I'll be selling my HP & SP4 and picking up a Surface Pro 2017 forthwith!
SurfacePro4_i7_Iris540_SW2018.reg - Google Drive
I have tried using that hex value (10000009) several times and followed exactly those instructions. When I do this and try to open up a file SolidWorks just crashes. I have also tried the other variations of hex values that others in this thread have listed. Still does not work for me. I am not sure what to do at this point. I am using the new Surface Pro 2017 and have updated all of the drivers including for my Iris Plus 640 GPU. Someone please help!
I have a Surface Pro 2017 and it seems like none of these hex numbers worked for me. How did you figure out what hex number to use?
Uh oh! I am anxiously awaiting the delivery of my new Surface Pro 2017. As I type, it's on the UPS truck and I'll have it tonight. I'll let you know how it turns out for me. I'll be very disappointed if it doesn't work.
Are you applying the attached registry-file? Are you running SW 2018?
I tried applying the attached reg file but it did not work. I am currently running SW 2017 so maybe that is why.
I just checked on my delivery...UPS was meant to deliver between 2:45 and 6:45...it's 2:00 here...they TRIED TO DELIVER @ 1:30!!! F'ing UPS...I made arrangements with work to take a half-day to be there for the delivery too (which requires a signature).
That's all...I just felt like complaining to someone.
Well, I got my Surface Pro 2017 last-night, and so far I'm a bit disappointed.
Out of the gate, SW18's responsiveness stunk, and I needed to adjust the Intel hardware registry key workaround to have it work properly. SW crashed the very first time after this "improvement" whilst closing an unsaved part. This alarmed me, but I haven't had another crash after several hours of poking around.
For reference, I have SW18 working nicely on a Surface Pro 4 with an Iris 540, and RealView's working flawlessly.
None of the Hardware/Shader registry Workaround hacks have breathed life into RealView thus far. I went to the extent of copying my SP4's SOLIDWORKS2018 registry-branch and BeyondComparing it (and updating) my SP5's...no go.
I even installed the latest Iris 540 drivers on the SP5 after fiddling with the installer's INF to fool it into thinking they were 640 Plus drivers ... nope.
I haven't given up yet though; I was ecstatic I'd gotten RV working so smoothly on my SP4, but I really needed more memory for other intensive processes I rely on my machine for...I figured the beefier SP5 with a "better" sibling graphics-card would be a no-brainier. Oh well...
As for Workaround DWORDs...if anyone can give me a primer on what they're doing exactly, and where these lists of mysterious symmetrical numbers come from, I'd really appreciate it. If I knew what they actually did, maybe I could intelligently adjust them to get things working.
I'll post any successes.
For my future reference:
80408
80008
40408
40008
60008
60408
31408
30008
30408
-Fitz
Which hex value did you use for your registry key in order to get SolidWorks to work properly? The hex values I have tried just lead to SolidWorks crashing on startup
Realview with Intel IRIS plus 640
After putting together bits and pieces of information, then troubleshooting problems after upgrading to Win10 Pro and then having it not work after updating to the latest video driver. I think I figured out what's important to make Realview work with Intel Iris Plus 640. Mine being on a Dell XPS 13 9360.
First Thing:
Running Regedit, go to Computer\HKEY_CURRENT_USER\Software\SolidWorks\SOLIDWORKS 2018 (or what ever year you're on)\Performance\Graphics\Hardware\.
Go to "Current", then double click "Renderer" and copy the name of your GPU as SolidWorks sees it.
Expand the "Intel" folder and you see several Intel cards but not ours. We need to have a key with the exact name we copied from the "current" folder. That key needs two sub-keys,V001 & V002, exactly like the other similar cards in the Intel folder.
There are two things you can do.
Create the new key and sub-keys complete with names and Dword values exactly the same as say, the Intel(R) HD Graphics P keys.
Or, since we don't have the Intel(R) HD Graphics P card, just rename it to be our Iris Plus card.
The values for all the cards in the Intel folder are the same except for the first one so don't use it.
Second Thing:
Now expand the "Gl2shaders" folder then the "Other" folder. Here you will find other Intel cards but not ours. Add a new key and name it exactly the same as the "renderer" in the "current folder".
Add to it a Dword (32 bit) called "Workarounds", and give it a value. At this point, it seems any value will work. I can even leave it set to 0.
Third Thing:
Pay attention to the first thing. When I updated my video driver to the latest, Realview stopped working. WTF? I searched the registry for every instance of "Intel(R) Iris(TM) Plus Graphics 640" and saw it didn't find the one in the "Current" folder. The new driver now calls it "Intel(R) Iris(R) Plus Graphics 640".
Notice the "Iris(TM)" is now "Iris(R)"? I renamed my keys and I was happy happy happy!
Got Realview on my laptop, The graphics act the same as my workstation, integrated preview and all, and it has a Quadro 600.
Hope this works for everyone with this GPU.
Steve
First a flawless SpaceX Heavy launch, and now THIS! This day can't get any better!
Thanks Steven; this worked exactly as advertised on my Surface Pro 5 i7. VERY happy!
Many thanks for taking the time to condense this!
I'm on an XPS 13 9370 and it totally crushes solidworks, love it. I have an eGPU but the stock intel graphics were borderline unusable before your fix.
I was able to do this work around for Iris 550 Graphics Card, but as soon as I finished editing my registry, SW is now crashing almost instantly upon opening. Any suggestions?
I was able to use this fix but now my SolidWorks is instantly crashing. Any suggestions?
This fix is for the 640. I posted a working registry-branch for the 540 earlier in the thread. Not sure it’d work for you 550. What machine is this on? Is it SW2018? And to clarify, you state you were “able to use” this fix, but SW crashes. That seems to imply RealView works, but SW crashes soon after. Correct?
I have been doing this on my Bootcamped Macbook Pro 2016 with Windows 10. I am using SW 2017. So before this fix, SW was incredibly slow and laggy especially with things in the Feature Tree (for example it would take about seven seconds to load a right click on a plane). After deselecting openGL, the response time was much faster, but as soon as I add a feature to a part, SW crashes.
I'm in a similar boat - using SW17 on a MacBook Pro 2018 (Iris Pro 655). This technique fixed terrible performance issues, but now Solidworks crashes whenever I try to edit a sketch. Any luck getting your issue fixed?
Howdy,
Just a follow-up on this for my own reference. After a recent Windows Update, this configuration failed. I then checked my Iris 640's driver-date, and it was updated to a May 2018 version. I rolled it back to the previous version (July 2017), and SW was back to normal.
Hope this helps others to avoid the momentary heartache I felt after trying to open my SW projects after a Windows Update, and having them CRAWL and with RV pulled out from under me. I'd actually shuffled around a few backup registration-files I had hoping to fix the issue, but the solution turned out simpler than I thought.
Hi John,
It's the 3rd thing on the list above. When I updated my graphics driver to the May 2018 version, same thing happened. I noticed they changed the name of the driver from Iris(TM) to Iris(R).
All you need to to do is change the name of the key to the same name you see under "current", which is "Intel(R) Iris(R) Plus Graphics 640".
Steve
I may have been to hasty with that reply.
I've been using the 2018 driver for several months now with no issues at all. Now as soon as I try to make a sketch, SolidWorks crashes. I couldn't roll back my driver as it was grayed out, so I downloaded the previous driver from Dell. They have an option to get it, but none earlier than that.
Now everything is back and working well. Must have been a windows update messing with the latest driver, then not agreeing with SolidWorks.
Hi Everyone!
Please see my fix described in my Technical Blog: SolidWorks on MacBook Pro - Eco-model
Best,
Lukasz Malecki
eco-model.eu
2019, happy new year!
This is just a status report on how I’m doing with RealView.
On my Dell XPS 13 9360 I updated the BIOS and all drivers from Dell, graphics included. Windows 10 is up to date. SW 2019 sp0 is installed.
Using the procedure above, I have RealView working with 2019. However, SW crashes when making a sketch. When I reinstall the most previous driver from Dell, which is “Intel-HD-620-and-Iris-Graphics-640_M10YG_WIN_22.20.16.4836_A09”, RealView works very well. Drivers from Intel don’t work on the Dell.
I also tried running the recent Real Hack 6.0.0. It made no difference in this setup, though it works very well with regular cards in a desktop and is easy to use. It works with 2018 & 19 and may work with earlier versions. It may work on other laptops as well.
Summary:
2019 RealView works with my Iris Plus 640.
Driver 22.20.16.4836_A09 is good.
Driver 23.20.16.4973_A10 is bad.
Steve
It works fine with SolidWorks 2020 on Surface Pro 4.
I've just tested and it's great!
Thanks for sharing.
Salvatore
