A knife gate valve sits betwen two piping flanges. Anysuggestions on how this can be added in routing. Currently the onlyway I can do it is to create a subassembly of the valve withflanges and insert it into a split in the pipe.SolidworksRouting
Answers10
SD
SD2009-06-04Best Answer
Hi Derek,
You are on the right track. or else you can also add the valveafter you add a flange, for that you will need a valve with routepoint and also the mates references will need to add.
Thanks and Regards
Sandip Darveshi.
SF
SF2009-06-04
I have a single R point at the centre of the valve and wishto insert this between flanges that have a C and R point. I'm notable to drop in the second flange for the valve. Have you been ableto do this?
SG
SG2009-06-04
Derek, I used to insert my valves as asseblies as youdescribe. You need to make an assembly with the valve and flanges.Then add AC points and AR point in the assembly. (that is thefittings themselves have a cpoint and rpoint but there needs to beassembly cpoint and rpoint at assembly level. Nice because you cansplit line segment and add fitting.
This worked with varying degrees of success. Mainly the problem wasreferencing issues. I would end up with multiple copies of theflange in many places due to poor copying practices and it wouldget confused where to look. Anyway it is doable but if you havemultiple users referencing the same library it can get messy.
Lately I have been doing something different. I just split asegment in 2 places (roughly the distance between flanges needed),then make sure the lines are co-linear and dimension the end pointsas needed. Still in the sketch I add construction line from endpoint to end point and place a point at mid point of the segmentfor placement of valve. Then I add flanges. Exit sketch and insertvalve at mid point. It stays centered between flanges and theflanges are dimensioned for valve laying length plus gaskets.
Seems like a lot but it really isn't. Pretty stable as well.
SF
SF2009-06-06
I tried it and it works Steve. A bit fiddly and I'd beinclined just to have a separate route before and after the valve.The valve gets dragged into the first route assembly.
DP
DP2009-06-06
Derek,
In the products that my company builds we often use valves thathave flanged connections. If the valve is flanged, we model it as apart with the companion flanges included into the part assembly.So, it does not really have to be a sub-assembly. But the pipefitters that fabricate the assembly really don't care. There isreally nothing to gain by showing each part on your BOM. Althoughlogistically, you have to send them the valve and the companionflanges as a package.
SF
SF2009-06-06
Thanks for that David. Can see that is possible. Nice fish bythe way. What do you call that. I also like fishing - with aspeargun in the ocean.
SG
SG2009-06-08
David,
How is it that you don't need to include mating flanges in a BOM?Are your fitters just concerned with layout?
I guess if you don't need to make a BOM for your routes then youwouldn't need to use router.
DP
DP2009-06-08
Steve,
About 90% of the flanged valves that I use are refrigeration valvesand they typically are provided with companion flanges.Refrigeration flanges are "special" male-female gasketed flanges.Although they are provided to me by my suppliers as a valveassembly, I just name the valve "with companion flanges" for theBOM. I think that this actually makes it easier for the fitters. Itcertainly makes it a lot easier for me.
It is also more accurate because my supplier's drawings are basedupon the distance between the companion flanges and include thetake-up necessary for the gaskets.
This approach wouldn't work if I found it necessary to include anexploded view to show how the companion flanges are to be boltedonto the valve, but most fitters don't need this much help. But ifyou want companion flanges as a separate entry on the BOM, then youprobably would also want the flanges gaskets, bolts and nuts aswell?? This makes for a lot of work, doesn't it??
SG
SG2009-06-08
Yes David it does make a lot of work. You are making mejealous since I have to add all this for my shop details. Theyactually wanted me to add washers at one point but that is where Idraw the line.
As it is I have a standard flange part and a mating flangeassembly. The assembly has 3 files: The flange, a studs with nutsfile, and a gasket file. The studs with nuts and gasket are partfiles with no geometry. Just a design table with allconfigurations. This way I can have all the BOM info for allflanges with thier associated hardware but not be bogged down byactual parts. It is still a pain sometimes when it comes to waffertype valves but mostly it works pretty smooth for standardconnections.
It would make things much easier to order a valve with matingflanges but I think in many cases that is not an option.
Thanks and Regards
Sandip Darveshi.
I'm not sure if I can help here, but this info might help - https://www.bmengineering.co.uk/products-by-type/valves/knife-gate-valves/
