Induction heating in a conjugate heat transfer problem!
Hello all
I am working on a conjugate heat transfer problem with a hollow cylinder with the following details:
1- The inner surface of the cylinder is heated by induction;
2- The outer surface is surrounded by a a metallic block which contains some channels for water flow for purposes of cooling the outer surface.
My questions are:
1- What is the best way to represent the induction heating in simulation ( Heat generation rate or heat flux or whatsoever...)
2- The contact between the cylinder outer surface and the cooling block, how can be dealt!
Thanks in advance
Mohamed
SolidworksFlow Simulation
