IDisplayData::GetLineAtIndex3 problem after Break
Dear Everyone,
I have a utility that creates horizontal dimension and places the dimension text in the middle of the 2 extension lines.
To determine the middle of the extension lines, I used IDisplayData::GetLineAtIndex3 to get the data needed then perform the computation as shown below:
<p>IDisplayData disData = (IDisplayData)tempDim.GetDisplayData();</p><p> double[] lineData1 = (double[])disData.GetLineAtIndex3(0);<br> double[] lineData2 = (double[])disData.GetLineAtIndex3(1);</p><p> // Calculate center;<br> double center = lineData1[4] + ((lineData2[4] - lineData1[4]) / 2.0);</p>
The utility works fine until I had to insert a break(View:: InsertBreak) in one of the drawing views that I`m working on,
the dimension text position is being placed in the wrong position.
Upon investigation, I found out that the value of lineData1 and lineData2 interchanged so the formula was affected.
I tried deleting the break line then re-create dimensions, and then the text was placed in the right position.
Based on this behaviour, I concluded that the break line is causing the problem, but I may be wrong.
Question:
Is there a way to prevent IDisplayData::GetLineAtIndex3 from interchanging the lineData1 and lineData2?
If none, what alternative function can I use to position the dimension text in the middle?
Thanks is advance.
Best regards,
Joecel
SolidworksApi macros
