I sketched a figure in ips units but it needed to be in mmgs. Is there any way that I can convert the units without having to redraw the figure?
Answers 15
EB
EB 2016-09-23 Best Answer
Matt,
If you go to Tools>Options>Document Properties>Units  you should see the image I am going to post below.  When you switch it to MMGS it'll automatically convert any sketch or feature values in your model.
~Eric
comment imagecomment image
BS
BS 2016-09-23
If you entered all the dimensions thinking it was mm, You will also have to scale your drawing by 25.4 (Scale Down).
EB
EB 2016-09-23
Babak,
Oh I just figured he had been using the right scale for everything but found out they wanted it displayed differently.
NN
NN 2016-09-23
My issue is that I already completed the drawing. But everything was in ips unit when it needed to be in mmgs. Do I have to draw the sketch over from scratch?
BS
BS 2016-09-23
That's probably what OP was looking for. I figure I'd throw in this part just in case, since this happens to me sometimes.
NN
NN 2016-09-23
what is op?
KL
KL 2016-09-24
OP = Original Post or Original Poster.
Just to confirm, are you talking about an actual 2D sketch in a drawing with no 3d model involved.
NN
NN 2016-09-24
correct, the whole sketch is 2-D
TC
TC 2016-09-24
You can do it here
VU
VU 2016-09-24
Follow   advice: change units in your drawing, not model.
NN
NN 2016-09-24
Since the drawing is complete, when I change the units it goes out of proportion.
DG
DG 2016-09-25
Changing units will bump up the dimensions values by a factor of 25.4 (1 in to 25.4 mm).
So if you don't want to change the values also then try this ModelRescaler​ macro from Lenny's SolidWorks Resources​. Do backup your files.
KL
KL 2016-09-25
I'm not able to test the ModelRescaler macro at the moment, but I don't believe the macro works on 2D sketches within a drawing document?
KL
KL 2016-09-25
Copy and paste the sketch into a new part, and then use the ModelRescaler macro suggested by Deepak.
You may have to create a 3D solid or surface first.
DG
DG 2016-09-25
I'm sure that OP is talking about a 2d sketch in the model and accidentally/unknowingly posted in Drawings/Detailing section.
If that is 2d sketch in the drawing, then best would be to convert that into a block and scale down by required factor
