I receive error messages when i try to reinstall Solidworks 2017 such as "The Installation Manager could not read a file that is required for installation: D:\\swwi\\data\\Solidworks.Msi." How can i fix this problem?
SolidworksAdministration
Hi Grant,
An error like this might happen if your D-drive is an optical disc drive and either the disc you are using for the installation is scratched, dirty or the optical drive's laser is too weak to properly read the disc. You could test whether any of these are the case by copying the full contents of your installation DVD to a folder on your local C-drive then run "setup.exe" in the root folder from there. If you have trouble copying the data from the disc it is a pretty good sign that something is dirty/scratched/weak. If it does copy to the local C-drive successfully and is able to install it could just be something impacting the speed at which the disc itself could be read. An installation from the local hard drive should work fine though if you can get that to proceed.
Have you solved this problem now? I'm now encountering the same problem as you
