i need to convert the ineer surface to parametric ineer surface using Loft function with guide curve
hello every body. i need to convert inner surface of the model which attachment to  inner parametric surface by using Loft function with guide curve.  Please any body help me because i don't have a good idea by using SW.
SolidworksParts And Features
Answers 19
SF
SF 2013-10-11 Best Answer
I think to accurately define the inner parametric surface, six section planes were used to capture the curvature over the entire model.  Also I think to maintain the continuity of the loft cut, all the planes were passed through the origin. and the origin also acts as a center of rotation. The Center of mass (CG) of the imported  model was considered as the origin to best define the center of curvature of the sweep cut.   please any body help me, how to make this parametric inner surface. i have just idea but i don't know how applying in Solidworks.
SF
SF 2013-10-11
Qasem,
Can you define what you mean by inner surface?  Are you talking about the extruded surface on the inside of the part or the Femoral bone surface on the exterior?
Regards
Mark
SF
SF 2013-10-11
Dear mark Biasotti,  I mean the Femoral bone surface on the exterior. (i mean implant-bone interface is the inner surface).  please, if you have any idea or have you time free. help me to finish this problem because i need to make good stress distribution of implant-bone  by making inner parametric surface.
SF
SF 2013-10-12
Dear mark Biasotti,    iam very sorry, i have mistake in the previous replay.   extruded surface on the inside of the part   (i mean implant-bone interface is the inner surface).  this part will be put to femoral bone in surgical operation   help me to finish this problem because i need to make good stress distribution of implant-bone  by making inner parametric surface.
TD
TD 2013-10-16
Hello Qasem, I do not understand what you are wanting help with? I down loaded your part and what I see is, what looks like the end of a bone?  From there I do not know what you are looking for? Tom
SF
SF 2013-10-17
Hello all,   i want to convert the attachment model which scan from CT scan and convert it to solidworks as the attachment.  please i want to convert this model to parametric model to producing this model by CNC machine, because CNC machine need (x,y,z) for each point in the model to producing any model. also if i need to change some of dimension.  also to test the distribution stress of the implant by using finite element analysis, need parametric model to apply the stress and forces in any point .  please any one help me to convert this model to parametric model , because i tried all method but without useful.
SF
SF 2013-10-17
Dear Tom dunn,    i need to convert the inner surface of the implant femoral as attachment to to parametric design to promote better bone ingrowth and uniform stress distribution.  attachment : figure like i need to convert my model. and attachment the model in solidworks.  so, i want to convert the inner surafce of the model like the inner surface of the picture which attachment by using Lofted cut function with guide curve.   please if any one have any idea, please help me to complete my project.  Note: you see the inner surface of my model is smooth , and the inner surface in the picture is made by using the loft cut function to promote distribution stress of the implant.  i need like the picture please.
RN
RN 2013-10-17
do you know what the "wall thickness" of your femoral knee needs to be?
comment imagecomment image
SF
SF 2013-10-17
I need the wall thickness from 5 mm to 9 mm .  and please when you are finished > can you tell me the idea and the command using in solidworks, steps by steps .  but now, the thickness is different from 5 to 9 mm .  thanks you very much .  when you are finished please also give me the model in solidworks 2012 if its possible
RN
RN 2013-10-17
where is 5 and where is 9mm, do you see the confusion here, you are not giving enough info qasem
SF
SF 2013-10-17
Dear Rico, Thanks you very much for help me .   I hope the attachment file about thickness wall is help you.  Now i want to make the approximate thickness and then i want to producing this model by using CNC machine, after that i willl meke test for the thickness.
RN
RN 2013-10-18
you need to specify the distance between the planes aswell
SF
SF 2013-10-18
Dear Rico,  attachment file solidworks , nearly i need the same plan in the attachment file.  i need the inner surface is symmetric shape   and please when you are finish, please write me step by step how is the method nd the using the command in solidworks.
SF
SF 2013-10-18
also may be the figures in the PDF attachment is help you   so, i need like this   thanks you very much .
RN
RN 2013-10-18
Qasem, it is unclear to me how come you defined the six sectiion planes using thoes points (not the CG but the other points) , unless i missed something the sketch planes are incorrect. Also in the word file the dimensions are different than thoes shown in pdf file
SF
SF 2013-10-18
Dear rico,   now i want to make just test for the model, and not importatnt the thickness waal and the plane . but iwant the final shape approximatly symetric for all inner surface, and i need approximate model in solidworks please , because i want to check it. and please tell me about the idea also step by step and also i will try again.  iam waiting to tell me about the final results and final model in solidworks.
SF
SF 2013-10-18
Also the point of the plane in defined in any place , to make continuity of the inner surface, and may be make  6 plane or 7 plane or above to make this parametric design , so not important No. of plane and the point of each plane and the thickness wall. but the importatnt is the final shape like in the word or PDF which attachment before.  so, please try to help me
SF
SF 2013-10-18
but all plane must be passing through the origin of the model , also the center of mass of the model is considered as the origin to make continuity of all plane. i think this note is very important to make continuity for all plane .  i tried to make like the pdf which attachment, but without good results.
SF
SF 2013-10-19
Dear Rico,  Pleas, can you tell me what happened about my design of femoral knee, iam waiting to listen good news.
