I need to add multiple dimensions to a feature in a drawing. I would like to duplicate the attached image without using simply inserting a note.
Thank you in advance.
-Brad
-Brad
Make it a table and flag it to the dim.
I know that you can add two lines of text, like tolerances or fractions to a note in NX, but I don't see any way to do it in the Note function. Am I missing something? If you can do that, then it would be a snap to recreate the note Bradley is asking about. If we can't do it, then I'd like to see that functionality added to SW instead of the goofy 50 shades of grey color scheme in 2016.
You can do it in a label or a note, but not in a dimension. If you add a blank dimension you can create a note with the desired text and just place it next to your dimension leader. You can create your tolerances and plate notes using the stack function (circled in red), but you only have 8 characters to work with. I had to put two together to do the plate notes. It's kind of kludgy, but it works.
Good luck!
Al
Bradley,
In SW2016, use the new "plating feature"!
Eddie
I've got reservations about going to 2016. There's some cool stuff in it, but I have to admit I'm not impressed by the new menu colors. It's not necessarily a deal breaker, but I like the existing (2015) UI.
Al
