I have renamed a configuration in and assembly. I created a derived configuration. Now I want to make my parent configuration my active configuration. Just can't get there from the derived configuration?
I tried a number of thing. Most of them commented out, ended up using the name to activate the configuration.
I am using SW2011.
There should be a way to get to the parent configuration from the derived configuration even if it means, just moving back up the ladder?
'Sets the active configuration to the named title
'MyConfigurationName = swApp.ActiveDoc.ConfigurationManager.ActiveConfiguration.Name
'swApp.ActiveDoc.ConfigurationManager.ActiveConfiguration.Name = swApp.ActiveDoc.GetTitle() & " - Open"
Debug.Print swApp.ActiveDoc.ConfigurationManager.ActiveConfiguration.Name
'Rename Active Configuration
swApp.ActiveDoc.ConfigurationManager.ActiveConfiguration.Name = swApp.ActiveDoc.GetTitle() & " - Open"   ', "", "", 1, swConf.Name, swApp.ActiveDoc.GetTitle())
        '(swApp.ActiveDoc.GetTitle() + " - Closed", "", "", 1, swConf.Name, swApp.ActiveDoc.GetTitle())
'Get Active Configuration
Set swConfig = swModel.GetConfigurationByName(swApp.ActiveDoc.ConfigurationManager.ActiveConfiguration.Name)
Debug.Print "My Config :" & MyConfigurationName
'Set swDerivConf = swConfMgr.AddConfiguration(swConf.Name + " Config Name Addition", "Configuration Comment", "User Specified Name BOM", 1, swConf.Name[Parent Configuration], "Configuration Description")
'Add a Derived Configuration
Set swDerivConf = swConfMgr.AddConfiguration(swApp.ActiveDoc.GetTitle() + " - Closed", "", "", 1, swConfig.Name, swApp.ActiveDoc.GetTitle())
swModel.ShowConfiguration2 (MyConfigurationName)
End Sub
SolidworksApi macros
Answers 6
SF
SF 2015-09-02 Best Answer
Dim instance As IConfiguration
Dim value As Configuration
value = instance.GetParent()
2011 api - GetParent Method (IConfiguration)
BP
BP 2015-09-03
Thanks Leon:
But I'm a little confused as to what goes where. Your tag to the program shows "Set parentConfig = config.GetParent"; Why would you want parentConfig if your trying to get config.GetParent? And in you example value and instance is which?
So your in the derived configuration and you want to get to it's parent, do you need to what the parent name is?
SF
SF 2015-09-03
     I'm sorry, but I'm not really understanding what you are trying to achieve.
     Are you on a child configuration and are trying to get to it's parent configuration?
     Check out this example:
2012 SOLIDWORKS API Help - Traverse Hierarchy of Configurations Example (VBA)
BP
BP 2015-09-03
Here is what I am trying to do.
In a blank assembly template.
I am trying to rename the first configuration. (i.e. to 'sample - open')
Create a derived configuration. (i.e. sample - closed).
And set it back to the first configuration, or parent (i.e. sample - open)
Shouldn't be that hard right?
The code works but, I have to change the configuration into a string and then show it.
Code:
Sub AddConfiguration()
Dim vConfigNameArr As Variant
Dim vConfigName As Variant
Dim swActiveConf As SldWorks.Configuration
Dim swConfig As SldWorks.Configuration
Dim swCurrentConf As SldWorks.Configuration
Dim swConfMgr As SldWorks.ConfigurationManager
Dim swDerivConf As SldWorks.Configuration
Dim bRet As Boolean
Dim swParentConf As String
Dim MyConfigurationName As String
Dim swComp As SldWorks.Component2
Dim swSelMgr As SldWorks.SelectionMgr
Dim swParentComp As SldWorks.Component2
    Set swModel = swApp.ActiveDoc
    Set swConfMgr = swModel.ConfigurationManager
    Set swConfig = swConfMgr.ActiveConfiguration
    If swModel Is Nothing Then
            MsgBox "Sorry! Need an active part or assembly to function." & vbCrfLf & _
                    "Please open a part or assembly."
    End
    End If
    If swModel.GetType = swDocDRAWING Then
    End
    End If
'swModel.ShowConfiguration2 (MyConfigurationName)
End Sub
SF
SF 2015-09-03
    But you already have the "Open" configuration name set in a string variable (MyConfigurationName), you should just use a command to show it:
<p><span style="color: #e23d39; font-family: 'courier new', courier;"> swModel.ShowConfiguration2 MyConfigurationName</span></p><p></p><p><span style="font-family: 'courier new', courier;">    Debug.Print swApp.ActiveDoc.ConfigurationManager.ActiveConfiguration.Name</span></p><p></p><p><span style="font-family: 'courier new', courier;">End Sub</span></p>
BP
BP 2015-09-03
Thanks I guess that just the way I’ll have to go. Was hope there was a way, not to have to fish out the name of the configuration, but guess not.
Thank you
