Hello everyone i was just wondering if the CSWP exams remails same for 2nd trial. As i failed my first time.
Thank you
SolidworksDocumentation, Certification, And Training
Thank you
no, it won't be the same. There is a larger pool of questions from wich will randomly choosen. Some times they negate the question, changes words and values or the order of the answers. So read carefully! But all-in-all it will be the same as at your 1st attempt.
Cheers, Heiko
What do you mean? There is no possibility that in fully defined assembly center of mass coordinates will change. Are you sure that you checked it according to correct coordinate system?
Also, do not forget you have to wait 30 days
But take that time to research online for guides on the cswp. I found a few posted here on the forum. Once you have taken the cswp the videos and tutorials will definitely help on some of the areas you had trouble with. Go back and look at your models from the first attempt and see if you can find any features that did not update correctly or possibly how to make those features in a better way.
I have never had a student who was unsuccessful on the 1st (or 2nd or 3rd) attempt tell me - "But the questions this time were completely different..." I think you will find it pretty much the same (in terms of competencies tested) the second time around.
Hello everyone thank you for the information. I need some more suggestions as last time during my segment 3 exams my software was giving me wrong answers. I realized that because i opened up my files and compared the answer later on i did that 4 to 5 times without changing anything in to the assembly and last time it showed me correct answer so is there anyway that i can improve my software performance in assemblies so that i will not have the same problem. I am using solidworks 2017 professional.
Thanks in advance.
Never expect the same stuff. When working with SolidWorks you should have learned that what worked for you last week or last year may not work for you today. Part of having this Certification is that you are able to deal with the problems and come up with the correct solutions. I got to see some of the student models and there are simple little things that caused the intern to fail. Work out the problems that you had and be sure that you will be able to handle any modeling problems. Then know where to be able to find the answers to the questions.
There is no guarantee that questions would be same. Even two persons giving exam side by side would get different questions. So prepare well and do it.
Best of luck!!
Hi Kartik,
questions change. There are several various model sets for CSWP exam. What is more, even when overall shape looks the same, dimmensions may be different.
