I cannot combine all bodies after inserting a multi-body part into a multi-body part.
I cannot combine all bodies! I add a multi-body part into my multi-body part. I cannot select all and combine. I tried ctrl+a in combine, but I only get the bodies native to my current multi-body part, not the multi-body part I just inserted. Any ideas? It is very inconvenient to just select all manually. This is a highly repeated part.
SolidworksGeneral
Answers 17
MB
MB 2021-04-08 Best Answer
Hi Stephen,
You should be able to do what you are doing, but for those of us on the forum, you need to post your file/s and/or example. Most probably there is some aspect about the bodies that you are trying to combine that results in a ZTG (zero thickness geometry) error.
Mark
KS
KS 2021-04-08
Yes this I understand. I write about this solution i my answer:
Can you try select this inserted part in feature tree?
But I see this solution in your answer. That's why I asked.
SR
SR 2021-04-08
So, instead of selecting ctrl+A to selelct all the bodies I want to combine, I have now found it more effective to just ctrl+click or shift+click on the bodies I want to combine in the solid bodies folder in the feature manager tree. Then, if there are a lot of bodies I don't want combined, I can just select the ones I need from the solid bodies folder, rather than ctrl+a and deselecting the bodies I don't want to combine.
KS
KS 2021-04-08
I steel stupid  Were is answer? You write in your message
This is why I always have the solid and surface bodies folders visible in the design tree. Helps keep track of such things in a part.
I don't understand.
SR
SR 2021-04-08
Instead of using ctrl+A to select all bodies, I used
The solid bodies drop down to select the bodies I was combining. A good enough work around for now!
comment imagecomment image
KS
KS 2021-04-08
I don't understand: where is this correct answer?
SR
SR 2021-04-08
Yeah, idk why ctrl+A doesn't work, but that's okay, I have all I need for now.
KS
KS 2021-04-08
A! You have a other problem. In topic you write
but you cannot select all bodies. Its other problem. Can you try select this inserted part in feature tree? But Ctrl+A  it should work.
SR
SR 2021-04-08
Thank you! This was it. I was trying to shift+click on the feature manager. What I needed to do was to click under solid bodies. Thank you so much!!
SM
SM 2021-04-08
SR
SR 2021-04-08
It is a body. The spherical things are the things that won't select in ctrl+a. However, you can see that I was able to manually select them.
KS
KS 2021-04-08
And... maybe inserted part is surface not solid?
SR
SR 2021-04-08
Unfortunately, I can combine them. No problems if I select all the parts. However, I cannot select all of them at one time. This is a big problem because there are like 60 of them now, and there will be like 150 by the end of the model. I don't want to have to click them all again if I need to make changes.
SM
SM 2021-04-08
Make sure the bodies your are combining are touching or overlapping. If there is space between the different bodies, the combine tool will fail.
SR
SR 2021-04-08
Files attached. The cutter file is used to insert prongs for holding a diamond while the central body cuts out the metal to allow diamonds to sit inside the ring. The prongs will have zero thickness geometry because they are right next to the central cutting body. However, even when I change their distance to make them not zero thickness, it still won't select the prongs when I select ctrl+a. I tried re-building multiple times.
KS
KS 2021-04-08
Maybe before selecting... Ctrl+Q ?
B.R.
JF
JF 2021-04-08
it sounds like you are just having problems selecting all of the bodies, correct? there are a lot of way to select things...
  1. have you tried dragging a box to select the bodies (after starting the combine feature)?
  2. have you tried shift selecting them from the "bodies" folders in the tree?
