i attached my program here please correct my program
Private Sub CommandButton1_Click()
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Dim longstatus As Long, longwarnings As Long
Sub main()
Set swApp = _
Application.SldWorks
Set Part = swApp.ActiveDoc
boolstatus = Part.Extension.SelectByID2("Front Plane", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
Part.SketchManager.InsertSketch True
Part.ClearSelection2 True
Dim skSegment As Object
Set skSegment = Part.SketchManager.CreateLine(-0.083999, -0.057931, 0#, 0.097241, -0.057931, 0#)
Set skSegment = Part.SketchManager.CreateLine(0.097241, -0.057931, 0#, 0.097241, 0.048827, 0#)
Set skSegment = Part.SketchManager.CreateLine(0.097241, 0.048827, 0#, 0.088137, 0.048827, 0#)
Set skSegment = Part.SketchManager.CreateLine(0.088137, 0.048827, 0#, 0.041793, -0.033931, 0#)
Set skSegment = Part.SketchManager.CreateLine(0.041793, -0.033931, 0#, -0.020276, -0.033931, 0#)
Set skSegment = Part.SketchManager.CreateLine(-0.020276, -0.033931, 0#, -0.071586, 0.048827, 0#)
Set skSegment = Part.SketchManager.CreateLine(-0.071586, 0.048827, 0#, -0.083999, 0.048827, 0#)
Set skSegment = Part.SketchManager.CreateLine(-0.083999, 0.048827, 0#, -0.083999, -0.057931, 0#)
Part.SetPickMode
boolstatus = Part.Extension.SelectByID2("Line1", "SKETCHSEGMENT", -0.031034257852077, -5.83444047619048E-02, 0, False, 0, Nothing, 0)
Dim myDisplayDim As Object
Set myDisplayDim = Part.AddDimension2(-2.85515172239108E-02, -7.98614902060115E-02, 0)
Dim myDimension As Object
Set myDimension = Part.Parameter("D1@Sketch1")
myDimension.SystemValue = TextBox1.Value / 1000
boolstatus = Part.Extension.SelectByID2("Point7", "SKETCHPOINT", -7.15856881121243E-02, 4.88272323539345E-02, 0, False, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("Point4", "SKETCHPOINT", 8.81372922998987E-02, 4.88272323539345E-02, 0, True, 0, Nothing, 0)
Set myDisplayDim = Part.AddDimension2(7.52465938892025E-02, 5.39403354766828E-02, 0)
boolstatus = Part.Extension.SelectByID2("D1@Sketch1@Part1.SLDPRT", "DIMENSION", 0, 0, 0, False, 0, Nothing, 0)
Set myDimension = Part.Parameter("D2@Sketch1")
myDimension.SystemValue = TextBox2.Value / 1000
boolstatus = Part.Extension.SelectByID2("Line7", "SKETCHSEGMENT", -7.80276122658087E-02, 4.91654896991768E-02, 0, False, 0, Nothing, 0)
Set myDisplayDim = Part.AddDimension2(-7.77581071437855E-02, 0.066413817508659, 0)
boolstatus = Part.Extension.SelectByID2("D2@Sketch1@Part1.SLDPRT", "DIMENSION", 0, 0, 0, False, 0, Nothing, 0)
Set myDimension = Part.Parameter("D3@Sketch1")
myDimension.SystemValue = TextBox3.Value / 1000
boolstatus = Part.Extension.SelectByID2("Line3", "SKETCHSEGMENT", 9.09501179352416E-02, 4.95129105965846E-02, 0, False, 0, Nothing, 0)
Set myDisplayDim = Part.AddDimension2(9.63656239296345E-02, 7.14328158119844E-02, 0)
Set myDimension = Part.Parameter("D4@Sketch1")
myDimension.SystemValue = TextBox4.Value / 1000
boolstatus = Part.Extension.SelectByID2("Line5", "SKETCHSEGMENT", 7.72551305096969E-03, -3.44094342691546E-02, 0, False, 0, Nothing, 0)
Set myDisplayDim = Part.AddDimension2(0.193302562314296, -4.74999315200947E-02, 0)
boolstatus = Part.Extension.SelectByID2("D4@Sketch1@Part1.SLDPRT", "DIMENSION", 0, 0, 0, False, 0, Nothing, 0)
Set myDimension = Part.Parameter("D5@Sketch1")
myDimension.SystemValue = TextBox5.Value / 1000
boolstatus = Part.Extension.SelectByID2("Line6", "SKETCHSEGMENT", -4.15563589525694E-02, 1.01191123338906E-03, 0, False, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("Line4", "SKETCHSEGMENT", 5.31572388042322E-02, 5.63208673372084E-03, 0, True, 0, Nothing, 0)
Part.SketchAddConstraints "sgSAMELENGTH"
boolstatus = Part.Extension.SelectByID2("Line5", "SKETCHSEGMENT", -6.13501345002576E-03, -3.51794635192099E-02, 0, False, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("Point8", "SKETCHPOINT", -8.62757014543012E-02, 4.95771926425102E-02, 0, True, 0, Nothing, 0)
Set myDisplayDim = Part.AddDimension2(-0.130879751958984, 3.79733152360433E-02, 0)
Set myDimension = Part.Parameter("D6@Sketch1")
myDimension.SystemValue = TextBox6.Value / 1000
boolstatus = Part.Extension.SelectByID2("Line8", "SKETCHSEGMENT", -9.00682017060531E-02, -7.45841051721924E-03, 0, False, 0, Nothing, 0)
Set myDisplayDim = Part.AddDimension2(-0.176311477712246, -1.29817651677683E-03, 0)
Set myDimension = Part.Parameter("D7@Sketch1")
myDimension.SystemValue = TextBox7.Value / 1000
Part.ShowNamedView2 "*Trimetric", 8
Dim myFeature As Object
Set myFeature = Part.FeatureManager.FeatureExtrusion2(True, False, False, 6, 0, TextBox8.Value / 1000, 0.01, False, False, False, False, 1.74532925199433E-02, 1.74532925199433E-02, False, False, False, False, True, True, True, 0, 0, False)
Part.SelectionManager.EnableContourSelection = False
End Sub
SolidworksApi macros
I think you're not getting responses due to the fact that this is more than likely (almost certainly) a recorded macro from Solidworks. But mostly because you haven't defined what your problem is. How do you expect people to offer free help when you say "fix it please" AKA "do this for me so I don't have to please."
The code you provided will draw a vblock every time you run it. Just save a generic vblock.prt with arbitrary values and edit them later with code.
I assume that since you are dividing by 1000 that you're using metric values.
This code will be in your main module.
Public Part As SldWorks.ModelDoc2
Public boolstatus As Boolean
Public longstatus As Long, longwarnings As Long
Public ModelName As String ' For filename with extension
Public Sub_Main()
ModelName = Part.GetTitle
End sub
'Change Dimension Values
Public Sub Change_Values(ValueToChange As String, SketchWhereLocated As String, TextBox As Double)
Part.Parameter(ValueToChange & "@" & SketchWhereLocated & "@" & ModelName).SystemValue = (TextBox /1000)
End Sub
This code will be your CommandButton1_Click() 'copy and adjust for each dimension you want to change.
Call change_values(D7, Sketch1, TextBox7)
All of that replaces that million lines of code that was recorded.
Let me know if that works.
Keep in mind I am no programmer by any means so I'm sure there is far better ways of doing this.
try this link for some more insight on this subject.
