When I try to define two global variables to same dimensionof two different configurations of the same parts, I tried to usespecify configuration in the equation tool, but it seems notworking. Do I use it wrongly or is there alternative anyway toretrieve the value I want.SolidworksGeneral
A workaround is to create a layout sketch at the top of your treewith dimensions linked to the global variable. Then you canconfigure those dimensions.
Basically I have multiple instance of same part with differentconfigurations in same assembly file. I want to capture onedimension from this part, which varies with configurations. I usedJason's methods at beginning, then I learned from this forum thatyou can capture the value from each instance of the part, whichserved my purpose quit well too.
I am still not sure how to use design table to capture dimensionsfrom differen configuration of same part. What's the syntax forit?
