How to use BOM Scaling with API?
BOM Scaling
Lets you scale the BOM size. Available only after you click the pan icon  in the upper left corner of an existing bill of materials in a part or assembly.
no find API code of bom scaling. follow code is replace code.
Private Sub eAsmFile()
    Dim Xls As Excel.Application, Rng As Range, oRng As Range
        Set Xls = GetObject(, "Excel.Application")
    Dim Path
        Path = Xls.ActiveWorkbook.Path & "\\PDF\\"
    Dim Sht As Worksheet, Str
        Set Sht = Xls.Worksheets("JB4715")
        Set Rng = Sht.Cells(1, "BH").CurrentRegion
    Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
        Set SwApp = Application.SldWorks
        Set SwModel = SwApp.ActiveDoc
    Dim sFileName
        SwApp.SetUserPreferenceIntegerValue swEdrawingsSaveAsSelectionOption, swEdrawingSaveSelected
    Dim nErrors As Long, nWarnings As Long
     'Dim fileConfig As String, fileDispName As String, fileOptions As Long
        For jj = 1 To Rng.Columns.Count
             Set oRng = Xls.Range(Rng(2, jj).Formula)
             Debug.Print oRng.Address
             Str = ""
             For ii = 1 To oRng.Rows.Count
                 Str = oRng(ii, 1) & Chr(10) & Str
             Next ii
             sFileName = Rng(1, jj) & ".eAsm"
             sFileName = Path & sFileName
''             Stop
             Debug.Print sFileName
             SwApp.SetUserPreferenceStringListValue swUserPreferenceStringListValue_e.swEmodelSelectionList, Str
             SwModel.Extension.SaveAs sFileName, swSaveAsCurrentVersion, swSaveAsOptions_Silent, Nothing, nErrors, nWarnings
        Next jj
End Sub
Private Sub del20160707()
       Set Sht = Xls.Worksheets("GeneralTable")
       Set Rng = Sht.Cells(5, "AK")
       ''Debug.Print Rng.Parent.Name
   Dim Str, tmp, ii, jj, Xx, Yy, Row
       Str = "材料明细表"
   Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2, SwDraw As DrawingDoc
   Dim SwSelMgr As SelectionMgr
       Set SwSelMgr = SwModel.SelectionManager
   Dim sConfNames(0) As String, bVisible(0) As Boolean
   Dim SwAnn As Annotation, Pp
   Dim SwTextFormat As TextFormat
   Dim ConfArr, swConf As Configuration
       ConfArr = SwModel.GetConfigurationNames
   Dim SwBomFeat As BomFeature, SwTabAnn As TableAnnotation
   Dim SwBomTab As BomTableAnnotation, BomTab As BomTable
       'For ii = UBound(ConfArr) - 1 To UBound(ConfArr) - 1
       For ii = 0 To UBound(ConfArr)
           SwModel.ShowConfiguration2 ConfArr(ii)
           Set swConf = SwModel.GetActiveConfiguration
           tmp = SwModel.Extension.SelectByID2(Str, "BOMFEATURE", 0, 0, 0, False, 0, Nothing, 0)
           Set SwBomFeat = SwSelMgr.GetSelectedObject5(1)
           SwBomFeat.Configuration = swConf.Name
           sConfNames(0) = ConfArr(ii) 'ConfName
           bVisible(0) = True
           ConfNames = sConfNames
           SwBomFeat.SetConfigurations False, bVisible, ConfNames
           ''Debug.Print ii, SwBomFeat.Configuration, swConf.Name, SwBomFeat.Configuration = swConf.Name
           'Set SwBomTab = SwBomFeat
           Set SwBomTab = SwBomFeat.GetTableAnnotations(0)
           Set SwTabAnn = SwBomTab
           With SwTabAnn
               ''Debug.Print .Type, .Type
               For jj = 0 To .ColumnCount - 1
                    .Text(0, jj) = Rng(1, jj + 1)
                    'Rng(0, jj + 1) = Int(.GetColumnWidth(jj) * 1000)
                    .SetColumnWidth jj, Rng(0, jj + 1) / 1000, 0
               Next jj
               Set SwAnn = .GetAnnotation
               Xx = Rng(2, 1) / 1000
               Yy = Rng(2, 2) / 1000
               SwAnn.SetPosition Xx, Yy, 0
               For Row = 0 To .RowCount - 1
                    .SetRowHeight Row, 180 / 1000, 0
               Next Row
           End With
           Set SwTextFormat = SwAnn.GetTextFormat(0)
           With SwTextFormat
               '.CharHeight = 0.2 '200 / 1000
               '.TypeFaceName = "黑体"
           End With
           'SwAnn.SetTextFormat 0, False, swtextfomrat
           DigitsSwAnn SwTabAnn '
           'SwModel.EditRebuild3
       Next ii
End Sub
SolidworksApi macros
Answers 0
