How to select reference axis of the mating components in assembly file by using macros?
Hi All,
I am creating a macro whose function is to select the part file's axis system and mate with the other part which is already there in the assembly environment. The macro firstly opens the part files from the folder after that it selects the reference axis of the part file and then mate with the already open part in assembly. The following is the code which i have written for this function:
Sub main()
Set swcomp = swApp.OpenDoc6(filename, swDocPART, 0, "", longstatus, longwarnings)
Set components = swAssy.AddComponent5(Partname, swAddComponentConfigOptions_CurrentSelectedConfig, "", False, "", 0, 0, 0)
    AssemblyTitle = swAssy.GetTitle
' Split the title into two strings using the period (.) as the delimiter
    strings = Split(AssemblyTitle, ".")
    ' You'll use AssemblyName when mating the component with the assembly
    AssemblyName = strings(0)
   strCompName = components.Name2()
Set swcomp = swApp.ActiveDoc
  Set swDocExt = swcomp.Extension
        matename = "Align" + strCompName
       FirstSelection = "Axis_System@" + strCompName & "@ " + AssemblyName
       SecondSelection = strCompName & "_Axis@ Tool_Spec_System " & "@" + AssemblyName
         boolstatus = swDocExt.SelectByID2(FirstSelection, "AXIS", 0, 0, 0, False, 0, Nothing, 0)
         boolstatus = swDocExt.SelectByID2(SecondSelection, "AXIS", 0, 0, 0, False, 0, Nothing, 0)
         If Not boolstatus Then MsgBox "Selection Error:" & refx
        Set matefeature = swAssy.AddMate3(swMateType_e.swMateCOORDINATE, swMateAlign_e.swMateAlignALIGNED, False, 0, 0, 0, 0, 0, 0, 0, 0, False, longstatus)
swApp.DocumentVisible False, swDocPART
End sub.
I am getting boolstatus = false and then it does not execute the matefeature command.
Any kind fo help is highly appreciated.
Thanks,
Raj Dave.
SolidworksApi macros
