How to rotate a disc between fixed angles such as 90degree, 180 degree, 360 degree,540degree, 720 degree
Dear friends,
please help me to make a mechanism in which a disc appox dia 540mm height 50mm of plastic PF, WOULD Rotate about its axis in clockwise as well as anticlockwise, but fixed between a angle such as 90degree, or 540 degree....
any suggestion , any mechanism is welcome..
please share your knowledge..
thanking you,
shravan R
SolidworksMotion Studies
Answers 9
SF
SF 2013-11-25 Best Answer
put it in an assembly so that it can rotate when you click and drag it
use a motor to turn it based on location over time
RS
RS 2013-11-25
I usually use angle mates to control rotation.  Motors are very unreliable (unless you actually want erratic motion).
SF
SF 2013-11-26
thanks for reply.
dear sir..
i need some physical device or mechanism below disc to control rotation angle,
so that while disc rotate it will not go beyond stopper i.e it will rotate between fixed angle for e.g 540 degree
so so disc will complete 1 and half revolution i.e 540 degree, and some mechanism or stopper will not allow further rotation so disc can again rotate in opposite direction again up to 540 degree...
but i dont want disc to move up and down, disc will rotate about its own axis.
please suggest some ideas...
SF
SF 2013-11-26
thanks for reply.
dear sir..
SF
SF 2013-11-26
build a simple model, post it, describe what you've tried, what it is supposed to do and where you're stuck. i'm not following what you're trying to do.
the method we describe will allow it to rotate about its own axis and will not move up and down.
i'm not sure how a "device" will allow something to move 1.5 rotations. thats where the model or a picture of your assembly will help.
SF
SF 2013-11-26
dear sir,
i have tried and i can achive 90 degree to 360 degree fixed rotations with help of long bolts(covered by rubber grip) placed from sides at different interval to stop further movement..
but i dont have any idea for getting 540, 720 degree fixed rotations...
for rotations above 360 degree, my present concept will not works...
thats why am looking for some ideas, help...
any geared, sliding, any knid of mechanism if can help , i appreciate...
thanking you,
SF
SF 2013-11-27
ah, you are looking for an actual engineering solution vs how to implement it in motion. IE, you don't have an idea on how to handle the situation yet vs not just having trouble with setting it up in the software.
you may want to add some background inforamtion about what the device is, what your constraints are..etc. that will help develop a solution.
MP
MP 2013-11-27
One way that leaps to mind is a gear on a bolt with jam nuts to stop it from climbing the bolt after the appropriate number of turns.
Another way to get over-travel is to have the stop for your bolts to look like this, which would be more plausible if it bent around, but I didn't want to model that this morning.
comment imagecomment image
MP
MP 2013-11-27
Just spitballing, but I'll bet you could come up with a simple mechanism 180 from the stop that takes the stop down the first time you hit it and puts it back up the second time--a lever or a Geneva wheel. I don't have the details, I'm a big picture guy.
