How to make selection of a dimension using Solidworks API c#
I am changing the display dimension. I want to make the selection of changed dimension in a drawing file using Solid Works API C#
Is there a way to select particular Dimension in a drawing file using Solid Works API C#
Thanks,
Girish
SolidworksApi macros
Answers 10
MB
MB 2017-11-27 Best Answer
Hi Girish Kumar,
Please try with below method it help you to select the dimension in drawing with respect to model display dimension.
2018 SOLIDWORKS API Help - GetCorresponding Method (IView)
Thanks
Manikandan
GK
GK 2017-11-27
In Solid Works 2016, where can i make selection of dimension in drawing file.In this scenario i don't want to deal with part file.
can you provide some help with few lines of code?
MB
MB 2017-11-27
Hi Girish,
Can you please provide the sample workflow.
Thanks
Manikandan
GK
GK 2017-11-28
Hi Mani,
I want to make this dimension select through Solid works API C#.I want the selection of a particular dimension in a drawing file through code but couldn't overcome the problem.If its feasible to highlight the selection of dimension please let me know
Thanks,
Girish
comment imagecomment image
MB
MB 2017-11-28
Hi Girish,
Please go through the code,I hope it give the idea to solve.
static void Main(string[] args)
            SldWorks SwApp = (SldWorks)System.Runtime.InteropServices.Marshal.GetActiveObject("sldworks.Application");
            ModelDoc2 SwModel = (ModelDoc2)SwApp.ActiveDoc;
            DrawingDoc SwDraw =(DrawingDoc) SwModel;
            //Activating the drawing view and add the dimension.
            SwDraw.ActivateView("Drawing View1");
            bool boolstatus = SwModel.Extension.SelectByRay(0.548750670735953, 0.454527552410178, -2000.2475, 0, 0, -1, 1.33869713731939E-03, 1, false, 0, 0);
            boolstatus = SwModel.Extension.SelectByRay(0.537726106075676, 0.555323572161285, -2000.2475, 0, 0, -1, 1.33869713731939E-03, 1, true, 0, 0);
            DisplayDimension Mydim = SwModel.AddDimension2(0.619771002485532, 0.508862906821227, 0);
            SwModel.ClearSelection2(true);
            //Get the annotation and selct the dimension.
            Annotation Swann = Mydim.GetAnnotation();
            Swann.Select(true);
Thanks
Manikandan
AB
AB 2017-11-28
<p>Girish Kumar wrote:</p><p></p><p>Hi Mani,</p><p style="min-height: 8pt; padding: 0px;"></p><p>I want to make this dimension select through Solid works API C#.I want the selection of a particular dimension in a drawing file through code but couldn't overcome the problem.If its feasible to highlight the selection of dimension please let me know</p><p style="min-height: 8pt; padding: 0px;"></p><p>Thanks,</p><p>Girish</p><p style="min-height: 8pt; padding: 0px;"></p><p></p>
What are your requirements for the unique dimensions that you want to select. Are you looking to select them if they are a specific length? Are you looking to select them by name? This would help us determine a better approach for finding your dimensions.
GK
GK 2017-11-29
Hi mani,
I need to select all the dimensions in drawing sheet, not just one.
GK
GK 2017-11-29
Hi Alex,
I am looking for selection of all the dimensions in drawing file by name using  solidworks api c#
AB
AB 2017-11-29
<p>Girish Kumar wrote:</p><p></p><p>Hi Alex,</p><p>I am looking for selection of all the dimensions in drawing file by name using solidworks api c#</p>
I played around a bit with this so hopefully this works for you as well. It selected all DisplayDimension objects in all views on the current sheet.
<p>        private void SelectAllDimensions(ModelDoc2 modelIn)</p><p>        {</p><p>            ModelDoc2 swDraw = default(ModelDoc2);</p><p>            IDrawingDoc drawing = default(IDrawingDoc);</p><p>            IAnnotation swAnno = default(IAnnotation);</p><p>            View v = default(View);</p><p>            Sheet swSheet = default(Sheet);</p><p>            long annoType;</p><p>            double start = DateTime.Now.TimeOfDay.TotalMilliseconds;</p><p>            try</p><p>            {</p><p>                // Get base model file for the drawing</p><p>                swDraw = modelIn;</p><p>                // Cast as drawing since we know it's a drawing already</p><p>                drawing = (IDrawingDoc)swDraw;</p><p></p><p></p><p>                // If editing template, exit to edit sheet mode</p><p>                if (!drawing.GetEditSheet())</p><p>                    drawing.EditSheet();</p><p></p><p></p><p>                // Set sheet object as the current sheet</p><p>                swSheet = (Sheet)drawing.GetCurrentSheet();</p><p></p><p></p><p>                // Set the view object to the first view on the sheet</p><p>                v = (View)drawing.GetFirstView();</p><p></p><p></p><p>                // Loop through all drawing views</p><p>                while (v != null)</p><p>                {</p><p>                    // Get annotation for current view</p><p>                    swAnno = v.GetFirstAnnotation3();</p><p></p><p></p><p>                    // Loop through all annotations in this view</p><p>                    while (swAnno != null)</p><p>                    {</p><p>                        // Get annotation type and set layer based on type</p><p>                        annoType = swAnno.GetType();</p><p></p><p></p><p>                        // For all objects of DisplayDimension type, do the following</p><p>                        if (annoType == (long)swAnnotationType_e.swDisplayDimension)</p><p>                        {</p><p>                            // Select the DisplayDimension object and append to selection (true = allowing multiple selections)</p><p>                            swAnno.Select(true);</p><p>                        }</p><p></p><p></p><p>                        // Set annotation to next before the while loop restarts</p><p>                        swAnno = swAnno.GetNext3();</p><p>                    }</p><p>                    // set the view to the next view. this will return null if there are no more</p><p>                    v = (View)v.GetNextView();</p><p>                }</p><p>            }</p><p>            catch (Exception e)</p><p>            {</p><p>                Trace.WriteLine(e.Message + " " + e.Data);</p><p>                MessageBox.Show("Select All Dimensions Error", e.Message + System.Environment.NewLine + e.Data, MessageBoxButton.OK, MessageBoxImage.Error);</p><p>            }</p><p>            finally</p><p>            {</p><p>                // Let go of all references to solidworks objects</p><p>                swDraw = null;</p><p>                swAnno = null;</p><p>                drawing = null;</p><p>                v = null;</p><p>                swSheet = null;</p><p>                GC.Collect();</p><p></p><p></p><p>                // Print duration for debugger</p><p>                double finish = DateTime.Now.TimeOfDay.TotalMilliseconds;</p><p>                Trace.WriteLine(string.Format("Select All Dimensions Duration: {0:#.00} seconds", (finish - start) / 1000));</p><p>            }</p><p>        }</p>
AB
AB 2017-11-29
Additionally, if you're selecting the dimensions by name, you can add an if statement around the Select() statement looking for the desired name.
Example:
<p>if (swAnno.GetName() == "RD11")</p><p>{</p><p>   swAnno.Select(true);</p><p>}</p>
