Sub main()
Dim swSelMgr As SldWorks.SelectionMgr
Dim swFeat As SldWorks.Feature
Dim swSketch As SldWorks.Sketch
Dim swSkRelMgr As SldWorks.SketchRelationManager
Dim vSkRelArr As Variant
Dim swSkRel As SldWorks.SketchRelation
Dim relType As Long
Dim i As Long
Dim Filter As String
Dim fileName As String
Dim fileConfig As String
Dim fileDispName As String
Dim fileOptions As Long
Dim swsketchmgr As SldWorks.SketchManager
Filter = "SolidWorks Files (*.sldprt; *.sldasm; *.slddrw)|*.sldprt;*.sldasm;*.slddrw|Filter name (*.fil)|*.fil|All Files (*.*)|*.*"
fileName = swApp.GetOpenFileName("File to Attach", "", Filter, fileOptions, fileConfig, fileDispName)
Set swModel = swApp.ActiveDoc
Set swSelMgr = swModel.SelectionManager
Set swFeat = swSelMgr.GetSelectedObject5(1)
Set swSketch = swFeat.GetSpecificFeature2
Set swSkRelMgr = swSketch.RelationManager
vSkRelArr = swSkRelMgr.GetRelations(swAll)
For i = 0 To UBound(vSkRelArr)
Set swSkRel = vSkRelArr(i)
relType = swSkRel.GetRelationType
If relType = 9 Then
Debug.Print relType
Dim VOP As Variant
VOP = swSkRel.GetEntities
Dim LINE As SldWorks.SketchLine
Dim POINT As SldWorks.SketchPoint
Dim K As Integer
Set POINT = VOP(1)
Debug.Print POINT.X
Debug.Print POINT.Y
Dim swsketchpoint As SldWorks.SketchPoint
Dim swmathutility As SldWorks.MathUtility
Dim swmathpoint As SldWorks.MathPoint
Dim swSketchBlockDef As SldWorks.SketchBlockDefinition
Dim vpoints As Variant
Dim pointcords(2) As Double
Dim J As Integer
If POINT.X = 0 And POINT.Y = 0 Then
Else
pointcords(0) = (POINT.X - 0.01)
pointcords(1) = (POINT.Y - 0.01)
Set swmathutility = swApp.GetMathUtility
Set swsketchmgr = swModel.SketchManager
Set swmathpoint = swmathutility.CreatePoint(pointcords)
Set swSketchBlockDef = swsketchmgr.MakeSketchBlockFromFile(swmathpoint, fileName, True, 1, 0)
swModel.Extension.SelectByID2 "", "POINT", pointcords(0), pointcords(1), 0, True, 0, Nothing, 0
POINT.Select4 True, Nothing
swModel.SketchAddConstraints "sgCOINCIDENT"
swModel.ClearSelection2 True
End If
End If
Next
End Sub
SolidworksApi macros
