How to get the path of each part of a sub-assembly through main assembly?
Hello everybody......
I need your help...
I have an assembly... which have some sub-assembly...
I used the code for calling the main assembly...
    Form1.ofd.Filter = "SW Assembly (*.SLDASM)|*.SLDASM"
    Form1.ofd.ShowOpen
    fileAsm = Form1.ofd.FileName
    Set swApp = CreateObject("SldWorks.Application")
    swApp.OpenDoc6 fileAsm, 2, 0, "", fileerror, filewarning
    Set swModel = swApp.ActiveDoc
    Set swFeat = swModel.FirstFeature
    Set swAsmDoc = swApp.ActiveDoc
    Form1.ofd.Filter = "Text file (*.txt)|*.txt"
    Form1.ofd.ShowSave
    newFile = Form1.ofd.FileName
    Open newFile For Output As fh
    Write #1, "File = " & swModel.GetPathName
Here we will get the assembly file's directory....and next i used this below code to get each component from the assembly file..
   Set swSelMgr = swModel.SelectionManager
    Set swComp = swSelMgr.GetSelectedObjectsComponent3(1, 0)
    Set swCompModel = swComp.GetModelDoc
    Set swCompModel = swApp.ActivateDoc2(swCompModel.GetPathName, True, nRetval)
    Write #1, "*******  Comp = " & swComp.GetPathName
But if the assembly file have sub-assembly it just show the sub-assembly as one component....
Can any one tell me the code how to call those components inside the sub-assembly by calling only the main assembly?
with regards,,,
Borad
NITW
Thanks in advance....
SolidworksApi macros
