I am trying to use a macro to compile a custom BOM as a CSV file and am running into a problem with getting the name of the components and sub-assembly components as I traverse the assembly. How do you get this information at the component file level vs at the assembly feature tree level?
When writing the name of the component it can not have the instance in it, or the assembly first with child component after.
What it is: component -1 what I want: component
What it is: component-1/Child-1 what I want: Child
so here is the section of code that is traversing the assembly and writing different values based on certain info in RawMaterial.
<p>For i = 0 To UBound(vComps)</p><p> Set swComp = vComps(i)</p><p> Set swCompModel = swComp.GetModelDoc2</p><p> If swCompModel.GetType = swDocPART Then</p><p> If swComp.ExcludeFromBOM = False Then</p><p> </p><p> 'Set raw material check ====================================================</p><p> </p><p> check = Left(swCompModel.CustomInfo("Rawmaterial"), 1)</p><p> </p><p> If check = "F" Then</p><p> Debug.Print "Number: " & swComp.Name</p><p> </p><p> Else</p><p> If check = "I" Then</p><p> Debug.Print "Number: " & swComp.Name</p><p> </p><p> Else</p><p> If check = "D" Then</p><p> Debug.Print "Number: " & swComp.Name</p><p> </p><p> Else</p><p> Debug.Print "Number: " & swCompModel.CustomInfo("RawMaterial")</p><p> End If</p><p> End If</p><p> End If</p><p> '====================================================</p><p> End If</p><p> End If</p><p> Next i</p><p>End Sub</p>SolidworksApi macros
