How to get and change Read Only property of referenced component (Part or Assembly) of Assembly in VB
I need a macro wich will work similar to Reload command in component tree on Assembly document (switch Read Only).
It should change Read Only mark on particular (selected) part / assembly.
Below code I have done:
Sub SwitchReadOnlyProperty()
    Dim swApp                   As SldWorks.SldWorks
    Dim swModel                 As SldWorks.ModelDoc2
    Dim swSelMgr                As SldWorks.SelectionMgr
    Dim swSelData               As SldWorks.SelectData
    Dim swComp                  As SldWorks.Component2
    Dim Name                    As String
    Dim longstatus              As Long
    Dim longwarnings            As Long
    Dim Komp1                   As String
    Dim boolstatus              As Boolean
    Dim Part                    As Object
    Dim selection               As Integer
    Dim File
    Dim nRetVal                 As Long
    Set swApp = CreateObject("SldWorks.Application")
    Set Part = swApp.ActiveDoc
    Set swModel = swApp.ActiveDoc
   ' checking is there any document is opened
    If swModel Is Nothing Then
        MsgBox "You don't have opened (or activate) any document"
        Exit Sub
    End If
     ' checking if Assembly is opened
    If swModel.GetType <> 2 Then MsgBox "You must have opened Assembly and one Component selected": Exit Sub ' Not Assembly is opened
        'Else - Assembly is opened
        Set swSelMgr = swModel.SelectionManager
        Set swSelData = swSelMgr.CreateSelectData
        Set swComp = swSelMgr.GetSelectedObjectsComponent(1)
        'is there any component selected
        selection = swModel.SelectionManager.GetSelectedObjectCount
        If selection <> 1 Then MsgBox "Nothing selected, or selected more then one component": Exit Sub
            'Else - Assembly is opened and one component selected, getting data to selected component
            Name = swComp.GetPathName
            MsgBox "File = " & Name 'this line just for info (to be removed)
            Komp1 = "Opened Assembly:          " & swModel.GetPathName & Chr(10) & Chr(13) & Chr(13) & _
                    "Selected Component:     " & swComp.Name2 & Chr(10) & Chr(13) & Chr(13) & _
                    "File:                                 " & swComp.GetPathName & " is ReadOnly = " & nRetVal & Chr(10) & Chr(13) & _
                    "Do you want to switch Read Only status of this component?" & Chr(13)
                    If MsgBox(Komp1, vbYesNo, "Change Read Only Status") = vbNo Then Exit Sub
    'STATEMENTS TO SWITCH READ ONLY PROPERTY OF SELECTED COMPONENT
    'reloading component
    'instance.ReloadOrReplace (ReadOnly, ReplaceFileName, DiscardChanges)
    'nRetVal = swModel.ReloadOrReplace(True, "", True)
    'swModel.ReloadOrReplace True, "", True
    MsgBox "File = " & swComp.GetPathName & "  Is ReadOnly = " & nRetVal
End Sub
Code above identify if there is assembly opened and only one component selected, but I have got problem with the most important part of the macro - how to get and change Read Only property of referenced component (Part or Assembly) of Assembly.
Any Halp appreciated
SolidworksApi macros
