How to force-create a failed feature?
There's a situation where I'm creating a loft feature with lots of profiles and guide curves. When I click OK, SW says that something is wrong with one of the guide curves. Is there a way to accept the loft to be created anyway as a failed feature? That way I can simply redo the offending curve, click rebuild, then everything should be fine. Instead, SW wants me to click Cancel on the loft feature, then I have to redo the curve, create the loft again, reselect all the profiles and guide curves, spending lots of time redoing the work I've already done once before.
In pro/engineer wf5 there is an option to create a failed feature, is there something similar in SW?
SolidworksParts And Features
Answers 3
MK
MK 2012-02-13 Best Answer
No, I don't believe there is.
A couple things you can try.
Remove the guide curve thats messing up the loft feature from the loft feature itself.  Then edit the guide curve sketch to fix it, and finally edit the loft feature and add the guide curve back in.
With the sketches used in the loft expanded in the feature manager tree (click the + sign next to the left), move the rollback bar to the bottom of the loft.  This will allow you to edit all of the profile and guide curve sketches without rebuilding (and failing) the loft.  Once you have all the profile and guide curve sketches set how you want, move the rollback bar back to the bottom of the tree.
SF
SF 2012-02-14
Thanks, but sometimes simply removing the offending guide curve from the loft feature will still cause it to fail, for example, a loft feature with only 2 profile curves, removing one profile curve will always cause it to fail. For other features as well, for example a simple protrusion up to a surface, you do all the work defining the feature (specifying sketches and settings), then it tells you that the surface is wrong, so you have to cancel the feature, modify the sketch or the surface, then define the feature all over again (the same feature you've already defined before). It's simply an annoying waste of time.
The ability to force-create a failed feature will greatly speed up things, as well as being more intuitive. The reason I like SW is because of the "fast and loose" approach, and this ability to force create failed features would fit right in with that ethos. I find it greatly amusing that Proe, which has always had a very restricting interface, is now ahead of SW is this department. It definately is something which should have been implemented a long time ago.
DL
DL 2012-02-20
John
I agree. It is much like trying to delete a feature without deleting its children. There are workarounds, but best just leave the children be. That is my choice for a default.
Dwight
