Hello, i'm newbie in solidworks and i have extruded some part with thin feature, but now realised that i had to do it using another method,so i want to disable thin feature (i want it to become without that hole inside without delting it and extruding again, because thn i try to delete it i get a lot of errors
SolidworksParts And Features
Hi Darius,
could you attach this part ?
See this Thread by
Hi Darius,
Delete the feature and make sure you don't select "also delete child features". Then roll back to top sketch and add boss extrude.
Then you have to fix the dangling relations of your child features....You cannot change a thin feature to a boss feature.
Option 2. Add a boss extrude to the inside of your thin feature. Just below the first feature and fill in the void.
Then fix the dangling relations of your child features...not pretty but works in a bind.
Option 3.
Select inner faces & delete them
RMC and select open loop edges then select delete hole. Do that for both sides
Voila Solid
Elmar
here
thanks, i'll try that, so as i understand if I will add filled extrude inside and delete external one, all relations should be ok? because if i try to delete extruded part, my sketches just broke,
Why not just select regions in you extrude?..
Hi Darius,
It took you two tries to upload the file. We all learn I suppose. Now you should specify which feature you want to change.
I would naturally wait till you have learned to properly formulate a clear questions. We will do that next time. Since your last feature
is technically a boss extrude, I show how to eliminate Thin 4 as an example. You can use the same technique to fix any of your lofts as well.
Next time I suggest you put a little effort into your question. What I do here is helping you to be complacent. Not something I want to support in general.
i'm sorry for bad formulation. While making this fuselage i made extrusions with thin feature, at first i thought that thickness which is beyond my sketch lines won't be a problem, but now i realized that it would be better to make solid extrusion and then make a hole in it for right sizes, so i wanted to delete these parts and extrude new ones which would be solid, but while deleting i got a lot of errors which ruin this file
