Hello, I have a simple piece of flat sheet metal, and on one edge I want to create a bunch of "fingers" all bent to the same length. SW gives me an error if I try to create these all in one bend. I cannot pattern these because they are not consistent. Do I have to create mutliple bends or is there a trick? I have attached a screenshot of a very simple version of what I am trying to do. Thanks.
SolidworksSheet Metal
I've done that type of flanging more than a few times but not in 2014, I don't know why it might be giving you an error. Can you post the part?
Thanks for the reply. Here is a simple version of the part file, we are in 2013.
Paul,
Perhaps the default bend radius is too large. Also I would recommend fully defining your sketches.
Chris
Doesn't work fully defined or with different bend radii. With a single bend in the feature it works, with it split into two bends it does not work.
The error I get with two flanges is "unable to create the edge flange"
Everything I have checked into makes me believe you will have to create another edge flange to make multiple. I know you can mirror an edge flange but if the second one is not going to be the same as the first then this is of no use. Tom
Paul make a single flange that runs the length of the edge, then faltten it and use a cut-extrude to add the finger-spacing.
Thanks, but I don't think that method gives you the proper relief for each of the fingers
Well, that's a good point. You'd have to draw in your own reliefs
Paul,
I don't have access to 2013 until tomorrow. I think I remembered how to make it work though. Don't flange it yet, sketch an cut-extrude your bend reliefs, then a single bend across all of the remaining 'tabs'. Perhaps the biggest 'secret' here is control-select all of your 'flanges' before hitting the edge-flange button.
Here it is in 2012:
It seems that fuctionality has also gone by the wayside, as is the case with just a simple sheet metal part. The new multi-bodied sheet metal procedure needs be changed to a selection that needs to be checked when needed and not the default sheet metal procedure. We have lost the simple sheet metal part for the multi-bodied sheet metal part. Sorry for the rant but "Really?".
Using SW14 here and it does not work either. You can control both flanges with one sketch as shown below. In the first sketch, make the second sketch construction lines and attach the second edge flange sketch to the first sketch.
You can solve this problem by using a split line on the edge face. The split face creates a segmented edge which SolidWorks will recognize and use in a sheet metal feature. Since you are using it to create flanges the subsequent faces are absorbed in the next feature and have no adverse effect on the model. See attached model. This solution is probably way too late for Paul but it may help others. It will work for as many flanges as you want and even on multiple edges with additional split lines preceding the flange feature.
Still same problem in SW 2018
See my previous post or post your model and I will show you how to get around this.
That does work and I hope they fix edge flange, that can support multiple sketch drawings.
There's no need to flatten it before cutting the fingers out, just make sure the normal cut is enabled and the cut extends into the radios.
Nicholas, a couple extra steps, but it is SW. Otherwise worked great. Thanks
