Good morning,
i'm using SolidWorks for quite a long time. But i have never needed to create complex surfaces.
Now i need to create a surface that will act as slide for a cylinder.
The idea is the cylinder is falling from the top onto the surface. Based on gradient of the surface the cylinder is turned for 90° and is sliding down/out.
Attached you find my current surface. You will directly see that the front right "corner" of the surface is not closed. Of course it needs to be closed to work. I have tried to close the surface by using different sketches.
But I'm not really come forward and i guess the way i used to achieve the current state is not the best.
For better unterstanding i have also attached a screenshot showing the (red) cylinder, that is falling from the top onto the surface.
Does anyone have suggestions or ideas how to create the surface in a better way?
Thank you very much!
Best regards
Matthias
Your attempt looks like it could work, but the cylinder could bounce about and needs to settle or rattle a bit before settling. What if it doesn't have to bounce or rattle and settle as much. Think of a slide or road going around a curve.
You need to consider how you'll make it.
Looks like you'll need a stamping mold for your design.
Or you can design it with just bending.
Does this custom slide part you're working on need to have it's input & output located beside each other? Or could the input be above the output? If it can be above, could have a "C" or sideways "U" shaped channel, tube, slide connecting both and keep things on one plane and simpler than making a custom slide that goes into another slide.
Thanks for your hint.
I will try it and let you know!
Hello Jesse,
thanks for your reply.
Your idea is good. In the area where this kind of slide is needed there isn't enough place to use a slide like on your images.
On the "output" of my slide the cylinder is passed over into another slide that is already designed like your idea.
With a cylinder diameter of 11mm the following slide will have about 20mm width. Combinded with the cylinder length the curve radius of the slide has to be at least 50mm. And this is the point why i need some other slide to perform the turn of 90° before.
First make surface between red lines.
After use Fill Surface to make corner (with tangent sides, top - contact).
