How to create a solid object from xyz points of a 3-D object??
I have a file containing the xyz coordinates of a model helicopter fuselage.  I imported the file using curve with xyz coordinates. I then was able to convert entities into a 3-D sketch but how can I create a solid object from these xyz coordinates. Any help would be greatly appriciated.
SolidworksImport export
Answers 4
SF
SF 2014-01-15 Best Answer
Stephen,
You can try using the Boundary feature to make a solid body, but I suspect that you would be much better off to make Boundary and Fill Surface patches. Knit all of the patches together and, provided you have done it right and knit will give you a water proof surface, you can thicken it into a solid.
I'm not sure how well this works with a 3D Sketch, as I tend to stay as far away from 3D Sketches as I can, having suffered much when they were new.
Jerry S.
LB
LB 2014-01-17
you will have to us the scan to 3d option, but it is only available in SW premium or the educational version as it is premium.
ScanTo3D Overview
Using the SolidWorks software’s ScanTo3D functionality, you can open scan data from any scanner (mesh or point cloud files) or curve data from mathematics software, prepare the data, then convert it into a surface or solid model.
When you open the scan data, you can open it as a new part document or import it into the currently active part document. Click Options in the Open dialog box and set the options.
ScanTo3D significantly reduces the time required to build complex 3D models from non-digital data. Designers can use ScanTo3D for various purposes:
  • Medical designers - Create anatomical objects for reference.
    Example of a solid created from scanned data of a hand, using the Surface Wizard's Automatic creation.
  • Consumer product designers - Create quick representations of physical components made from clay, foam, etc.
  • Machine designers - Create quick references to OEM parts.
ScanTo3D is available only in SolidWorks Premium. To activate ScanTo3D, click Tools > Add-Ins, and select ScanTo3D.
If you have a NextEngine scanner, click NextEngine Scan (ScanTo3D toolbar) or Tools > ScanTo3D > NextEngine Scan to start NextEngine scanning.
Overview of the ScanTo3D Process
Contents
SF
SF 2014-02-07
Hi Lenny,
Thanks for your reply. ScanTo3D works although I haven't mastered it yet and its hard to achieve a perfect model.
Regards,
Stephen
LB
LB 2014-02-07
Stephen,
I will tell you none of the software's I have tried to use for reverse engineering a scanned file are easy to learn and master!!!
so don't get overly frustrated ..... it is just the way and takes a lot of trys and mistake to get what you want.
worst yet most of the companies don't have training, just vids.
