Is there a way to create a mirrored assembly?
I played around with it, and I seem to be mirroring all the components in the assembly (creating all new filed), which I don't want to do. I want the same components to be used, just oriented 180 degrees from the original.
Thanks.
SolidworksAssemblies
Hi Michael
there are some additional options in the assembly mirror (1.)
If you have the second option deselected (2.) (create opposite hand version) it will not create new parts (or configurations)
Hope this helps.
Leszek
Another option that might work for you, depending on your circumstances, would be to start a new assembly. Insert the Assembly you want mirrored. Mirror this sub-assembly in the new assembly, then hide the original.
I don't see any issues mirroring a Subassembly, it's top level assemblies that seem to be the problem. If you're trying to mirror a top level assembly you'd want to do what Glenn suggests or just create another instance and put it in place. Hope this helps!
Thanks all.
This helped.
I wasn't noticing the arrow button that opened up more options.
