How to automatically start SW when computer boots up?
I'm in a scenario where I'm remoting into my machine, and I need solidworks to be running BEFORE I connect remotely.  This is related to the OpenGL issue.  If someone is at my machine and they log in as me, and start solidworks, and THEN I connect to the machine, the system runs using the host computer graphics hardware. However, if I connect and then start solidworks, it opens with OpenGL.
I've tried setting up autologin and putting SW in the startup folder, but it still waits until I connect to start.
I also tried starting from the registry.
I also tried using the windows task scheduler... this one starts a process named sldworks.exe, but it never produces the splash screen or shows any indication of running.
Any and all help greatly appreciated!!!
Matt
SolidworksAdministration
Answers 6
CE
CE 2014-07-29 Best Answer
Take a copy of the Solidworks desktop icon and drag it to the start bar, then hold it over all programs until it expands and then move it to the startup folder and drop it in there.  It will automatically start when startup your computer...hence the term
Chris
SF
SF 2014-07-29
Thanks, Chris, but that doesn't do it. It was the first thing I tried.  What happens is the computer starts, but the startup program (SW) doesn't run until I  connect to the computer.
Just to help clarify my dilema, all of the methods I listed in the OP do start SW, but none of them start SW prior to my connecting to the host computer.  The auto login is working... I don't have to type in any credentials, but it seems like the system "waits" to see me connect before running SW.
Message was edited by: Matt Walston
CE
CE 2014-07-29
Try making a script file.  Open up notepad and type the following and save it as RunSolidWorksScript.bat and put it in the startup folder to see if it works. Change the part between the quotes to the file path where your solidworks executable is located.  It should be close to what is there.
start "C:\Program Files\SolidWorks Corp\SolidWorks" SLDWORKS.exe
Hope this helps!!!
Chris
***UPDATE***
I just tried it on my computer and it worked!!!
SF
SF 2014-07-29
Thats exactly what I did. then saved it as a .ahk.
I attachem mine if you want.
Run C:\Program Files\SolidWorks Corp\SolidWorks\SLDWORKS.exe
SF
SF 2014-08-04
As it turns out, you are all correct.  The problem was with my automatic logon credentials.  Once I was properly logged on, startup folder works, script / batch file works... heck, I can't even find a way to break it now!
Thanks for the help everybody, and sorry for the operator headspace.
CE
CE 2014-08-04
Matt,
   Glad it worked for you.  To remove it you should be able to go to Start - All Programs - Startup and then delete the program/scripts you do not want to start automatically after startup.
Chris
