How to a set up a equation when modelling a steel beam when adjusted over a certain length the thicken and size of the beam will change.
I'm designing a steel frame construction and all the lengths and cross bars are individual parts which will bolt together. I would like to have the cross bars and legs size and thickness to change if the spread/width/length of the frame is increased.  Iv seen this done function work but would like to know how thank you
SolidworksParts And Features
Answers 2
SF
SF 2015-05-11 Best Answer
Hi Jack,
        Could you please send a snapshot of what you are looking for.
I Will be able to help you on this regard.
Thansk,
Joseph.I
SF
SF 2015-05-12
Hi Joseph,
Yeah no problem...
The cross bars running in a rectangle I would like these to be able to be adjustable via equations and for example the current model is spanning 2 meters if I was to increase to 4meters the crossbar would have to be a thicker stronger box sections. Would I have to have a separate part file built from the stronger box section or is the an equations formula which will change between a part configuration ?
Thank you
Jack
comment imagecomment imagecomment imagecomment image
