How many drawing sheets until poor SW performance
Using SW2009 SP2.0, I have dual quad core xenon processorsand a Nvidia Quadro FX 1700 with approved drivers and 3Gb memory. Iam wondering if anyone else strings together multiple drawingsheets from an assembly and has experienced poor performance after10 or so sheets. Poor performance in that when you select anythingit takes 5 to 15 seconds before you can drag or create dimensions,move views, etc. Once you can use the command everthing moves greatand then when you accept the location it again waits 5 to 15seconds before you can move on.
Any suggestions would be helpful.SolidworksDrawings And Detailing
Answers 9
MK
MK 2009-03-12 Best Answer
When you open the drawing, in the bottom right of the opendialog box, select only the sheet you're going to work on to load,the rest of the sheets should say (Quick View) after them.
SF
SF 2009-03-12
Mark,
Thank you for the reply. Is quick view an option I can set? Icannot find it in the options area.
SF
SF 2009-03-12
Mark,
I now understand what you were saying about quick view, sorry I waslooking in the options. II have done that now and am still havingthe same problem when dragging or creating dimensions or draggingviews. It is slow going. Any other suggestions?
MK
MK 2009-03-12
Some more details about what you're working on and your setupwill probably be needed. How large is your assembly? Are youworking over a network? How many views are on your drawing (I'vealso hidden all views except what I'm working on to improveperformance)? In options, how high is your image quality set to?What other apps are running on your machine the same time you arerunning SW?
JH
JH 2009-03-27
One of my users is experiencing the same problem. She isrunning a Dell T7400 with 4GB RAM and a Quadro FX 1700. Her drawinghas seventeen sheets.
We are all running the latest video drivers from the Solidworkswebsite.
The drawing is a process drawing showing the machining stages for acrankshaft. It is only a single derived part, but it is rathercomplex and has several configurations.
DD
DD 2009-03-27
"How many drawing sheets until poor SW performance?"
I can't believe some crank hasn't posted "one".
There is a limit, somewhere, depending on what sort of project youhappen to be working on. Because I can't predict where the slowdownwill come, I abandoned multi-sheet files as fully as I could backin '04. Sometimes I could get 25 sheets before things slowed to acrawl, but if I had 25 to go... Yes, there were some conveniences Igave up, like automatic sheet numbering, but they weren't enough tooutweigh the performance gains.
But sometimes, one sheet is enough to kill performance. Complexoffset section views of large assemblies are murder on performance,for example. Hiding such views while you work on other things canbe a big help. Or, just hiding every view you're not workingon.
JH
JH 2009-03-27
The most I had ever done was about 6 or 7 sheets. Now 1 or 2is normal. But our processing and machine designers use multiplesheets quite often.
It looks like if they want better performance they will have tolimit the number of sheets.
SF
SF 2009-03-27
I have drawings that are 40+ sheets of rather largeweldments. I don't know if the number of sheets is as important asthe number of views. The way I understand it is SW calculated themodel for every view.
Section Views, Detail Views, Relative Views are most likely moretaxing as SW would have to load the model and then calculate how tocut it etc.
Lorne
AW
AW 2009-03-28
On large drawings, with a lot of sheets, views, etc you maywant to look at your memory usage.
Could be bumping up against the limits of an x32 bit system. Maybenot enough to go over, but enough to not have the head room neededto work with the data set efficiently.
Cheers,
