How do I remove this material with Trim/Extend
Hello All.
I'm struggling with trimming the body shown in the picture below. In this weldment, I run into this scenario multiple times. I don't remember having this issue with 2018 but after upgrading to 2020 sp5 I feel like no matter what I do using the trim extend feature I can't get it right. Any help would be really appreciated.
SolidworksWeldments
Answers 5
MN
MN 2021-03-26 Best Answer
It is difficult to find out the location from this large structure. Try Delete and Patch.
comment imagecomment image
JS
JS 2021-03-26
It's Trim/Extend6, where the 2x2x3/16" L angle meets the 4x5.4 C channel.
I see the same behavior in SW 2017 SP5, so I doubt it was any different in 2018.  The basic problem is that the C channel and L angle profiles are not compatible with one another at this intersection.  The C channel has a radius transitioning to a small flat:
whereas the L angle is just a radius:
If you select Faces as the trimming entity instead of bodies, you will get something that looks better:
comment imagecomment imagecomment imagecomment imagecomment imagecomment image
ZW
ZW 2021-03-26
Thanks for responding so quickly. If you look at any one of the intersections where an angle meets the open profile of a channel you should see it.
MN
MN 2021-03-26
It should be like this:
KC
KC 2021-03-26
Like Maha, I'm not able to find where the images are located in the weldment.
Kevin
