How do I hide or remove these dimensions that show up in my assembly?
Needs some Help! Below is a sub-assembly of a molded part and metals. When I insert this sub-assembly into my mold all these dimensions show up. I'm guessing that there is an option or a setting that I can change to remove or hide the dimension? Any input would be greatly appreciated.
Thanks,
Rod Melching
SolidworksAssemblies
Answers 4
TC
TC 2012-01-03 Best Answer
View-Hide all types
RM
RM 2012-01-03
Tony,
Thank you very much! After following your sugestion, I still have ten or so remaining. Would I have to do the same thing on the sub-assembly level?
Thanks,
Rod Melching
SF
SF 2012-01-03
Rod,
After selecting "Hide All" (or de-select "All Anotations") in View you can try a rebuild or do Ctrl+Q. I had a few extrusion dimensions showing after Hiding All and rebuilding made them go away.
If you would like to hide the dimensions for specific parts you can find it in the tree of your assembly; right click on "Annotations" within the individual part and de-select "Show Feature Dimensions" and/or "Show Reference Dimensions".
Regards,
Jesse Butwinick
RM
RM 2012-01-03
Jesse,
I will definetly try that, thanks again for your input and sugesstions.
Rod Melching
