How do I find a specific part in an assembly when I only have a configuration description?
I am trying to find parts within an assembly. But all I have when searching is the description, which is in a configuration specific property of that part . How do I quickly find that part, even if it's in a suppressed sub-assembly?
SolidworksGeneral
Answers 9
KC
KC 2021-03-26 Best Answer
Try typing in the search box at the top of the tree.
May not work for suppressed.
Kevin
KS
KS 2021-03-26
Elmar Klammer wrote:
Search Criteria for Advanced Component Selection
  Above you have correct answer!
KC
KC 2021-03-26
Steven Mills wrote:
Doesn't work when what your looking for is a configuration property.
According to SW help:
comment imagecomment image
EK
EK 2021-03-26
WM
WM 2021-03-26
Set your Tree Display to Show Component Description. Now you can use the filter that Kevin mentioned.
JS
JS 2021-03-26
I never said you could search.  Just sort.  But finding it in a sorted list is faster than an unsorted list.  And you get the config specific properties s well.
The search field at the top only looks in the file name column.
SM
SM 2021-03-26
That is promising, but I can't seem to search with it. I type a word that I see is on one of the parts, and everything disappears from the visualization list.
SM
SM 2021-03-26
JS
JS 2021-03-26
You can also use Assembly Visualization and add a custom column with whatever you want (Description, custom properties etc):
Then you can sort to make finding what you want easier.
