Hi, I'm new to SolidWorks and attempting to cut a cylindrical tube to create a 15 degree angle at one endpoint. I'm not sure the best and simplest approach to do this, I'm attempting model medical needles. Thanks for any help.
SolidworksParts And Features
Draw a line making sure it extends to the edges, then cut-extrude and check the flip side of cut box.
Btw, it's good form to post your part file... It helps us help you better.
Edit to Add: Your version of SW is older than mine (I'm assuming you're using the student version). So here's a video:
pick a plane
make a sketch and then do a revolve, then a cut ?
Draw 15 deg triangle. Cut through the tube.
