How do I create a tube with different diameters at the two ends?
I need to create a tube that has different diameters at the ends. I have tried boundary base and lofted base, and they both create a solid that gets smaller before getting larger. I essentially want a straight line from one circle to the other revolved around the center. Is there an easy way to do this?
SolidworksParts And Features
Answers 10
JF
JF 2016-10-03 Best Answer
if the path is straight, you can use a revolved boss.
for the loft or boundary to be smooth, you will need to make certain that  the "connector" is aligned from end to end. and you will need to finish it off with a shell to make it hollow.
JP
JP 2016-10-03
Sure ... I did a Revolved Thin but I'm sure there are plenty of ways.
comment imagecomment imagecomment imagecomment imagecomment imagecomment image
DS
DS 2016-10-03
You basically answered your own question.  You're wanting to make a profile revolved about a center axis...try using Revolve.
JS
JS 2016-10-03
Then if you want some shape to it you can create a loft either as a thin feature or you can shell it.
DD
DD 2016-10-03
Wasn't this the impervious tube in space that ate planets and everything in its path in one of the original episodes of Star Trek?
BD
BD 2016-10-03
It won't let do revolve in a 3D sketch though. I have to connect multiple sections of these together.
JS
JS 2016-10-03
Yes it was. Either that or it was one of the worm holes.
DS
DS 2016-10-03
I don't see why that forces you to use 3D sketches...?
Can you upload your part?
If not, can you at least share some screen-shots so we see what you are trying to do?
JS
JS 2016-10-03
Are you trying to create both ends of the tube with one sketch? That would be the reason for 3D sketch. You want to use a different sketch for each end. look at my screen shot.
SC
SC 2016-10-03
I'm feeling violated with this post.
