how can we add sheet metal Thickness to Design Study parameters .??
when i try to select thickness as paramerter in optimazation study i can't do this >>
SolidworksSimulation
Hi Mohamad
1. You can add global variable say "T" and link it to thickness. (hope you know about equation)
2. Add global variable to design study parameters.
thank you mr.Yuvaraj
the thickness can't be added as a global variabel (see pic 1 ) and can't be seleted from drsign parameter .
any other paramter can be selected like radius (see pic 2 )
and when i try to go equation folder the thikness is locked and can't be modified .
thank you for your patient
might be worth posting your model and version/service pack.
also, haven't had a chance to check, but you might want to check the soldiworks knowledgebase, this looks like amatch for your needs: S-062689. you should just be able to choose the dimension.
Hi mohamad....
You can actually add it as model dimension in design study..:)
