HI, Is it possible to simulate a moving propeller in a fluid, but with propeller moving and not fluid??
HI, Is it possible to simulate moving propeller in a fluid, but with propeller move and not fluid?? I need to know how propeller can move a fluid and its effect, because flow doesn´t have a possibility to move the propeller only the fluid.thanks
SolidworksSimulation
Answers 5
AP
AP 2015-07-20 Best Answer
You never heard of action and reaction? Newton's third law?
Newton's Third Law of Motion
FB
FB 2015-07-20
Dear Andrei
Sorry, but I think you don´t understand my question. My problem is a little more complicated than using Newton´s 3 law. In my problem there is a lot of thinks that you must consider, for example the RPM is so low and if I use "N3Law" the results ate not representative. I need simulate a big system (40 meters of diameter).
AP
AP 2015-07-21
IT does not matter the principle still applies, I never heard in CFD simulation to move the object through air.​
so for your situation there is an example in the Tutorial.pdf in which you can set up a rotating region with whatever RPM you have there and then after solving the solution you can read the forces on your propeller blades. At this diameter it should be a wind turbine. Also there is plenty of youtube tutorials with setting up a rotating region in Flow Simulation.
Solidworks Tutorial - Adding a rotating region to a flow simulation - YouTube
SOLIDWORKS Flow Simulation - Going Deeper Into Your CFD Analysis - YouTube   (GO to min 20)
SolidWorks Flow Simulation Tutorial, Rotating Reference Frame to Calculate Thrust of a Propeller, HD - YouTube
2016-01-02
setting the fluid velocity x,y or z in initial and ambient conditions to the number you want will achieve the same effect plus a rotating region to simulate the propeller rpm.
FB
FB 2016-01-04
Hi Dave, thank you so much. I did it.
