I have attached a file. I am trying to get the tool body to sweep through the solid without rotating or twisting. I am stuck. Can someone take a look at this of me. I feel that I must be missing something because I am not asking a lot of the software I don't think...the files are attached. Open the one named "Illumina 768 Sweep Experiment" The other file is the tool body, and is inserted into the main part.
New forum blew my mind. I don't know where I am any more! Looks nice though. Holy crap! I just attached a file. Very nice compared to the old forum!
SolidworksParts And Features
That's definately something for your VAR. It should work. I have a suspicion that it is one of those zero thickness mysteries. Should work if you use follow path and direction vector with the top plane as the refernce...
hmmm....
Paul,
Sounds like it should be simple, but I'm in the same boat as you. I can't figure it out. I would call your VAR, otherwise hopefully one of the power users will have an idea.
I can't swallow that it can't be done with a sweep. I'm going to post this to my VAR. Seems like everytime I try something new, I "find the one possible way to do it wrong"!
I'll post the solution if I find one.
My VAR says it isn't going to work, but it is supposed to. SR issued, but we all know what that means...nothing. I am waiting for my VAR to show me how to model this in solidWorks. I need a geometrically accurate representation of this as if the form tool was mounted in a CNC and an arc was machined in the X-Z plane. I can't fudge this.
Anybody know how to model what I am after, accurately?
I was told this is a limitation of SolidWorks, and that the Parasolid kernel can handle it, and does handle it in other applications. What an annoyance, and an embarrasement to me as well because I can't model what I explained to our customer. Thank god I can machine it in a piece of steel to show the concept to the customer.
Thanks guys. Still open to ideas....
I agree, this is a bug. You can't use guide curves, and the Keep Normal Constant doesn't work, so you're out of options if you want to do this as a solid sweep.
My guess is that there is some easier way to do this than a solid sweep.
Try this, and I'd do it as surfaces so you can do one face at a time instead of all at once.
Sweep the diameter of the end of the cutter along the arc path.
Then create a split line on the swept surface at the angle of the side of the cutter.
Delete Face to get rid of the part of the face inside the cutter
Then make a ruled surface tapered from vector by the angle of the side of the cutter.
You may have to revolve some profiles on the ends to close up the surface
That ought to get you all the faces you need to make a cut in the block.
What version did you use for this? 2009 is supposed to have some changes that clean up solid sweeps a little.
Removed my post.....
See Paul's later post he has it sorted now on how to get this swept solid body to work.
Cheers,
Anna
It is something like this that truely frustrates me.. This is something seamingly simple, and SW should be able to do it... and yet... no solution.
Maybe in SP5.0 / SW'10?
Thanks Matt. I used 2009 SP3.0, so I am a SP behind. I'll try SP4.0 before I give up. I can try surfacing it. I was hoping to keep it simple so changes are easy as this detail is going to change frequently during research and development, along with the fact that this is going to be part of a 768 member pattern and is going to be frustrating to rebuild. Yes, the entire 768 pattern in necessary in the model. This is a whole new issue I have with SolidWorks.
I'll see what I can come up with, and I'll share the results if and when I get there. I see Anna has some suggestions, so I am going to take a look at what she's done.
Paul
Paul,
Matt has a better idea. We have the same line of thought, the taper is not the way to start the surfacing like I did.
Cheers,
Anna
Anna,
I'll dig into this Monday and see what I can come up with. What do you mean about my original models? Are you talking about something old? Funny, I was going to ask you about your system because I need to work on this project with 768 instances of that detail. I do this alot in plate versions with 384, 768, and 1536 patterns.
I am going to build a killer system as soon as I get the time. I will probably have a lot of questions for you if that's ok. I am cool with building the system, but some of your experiences with the lates and greatest will be valuable to me. I am tired of waiting on my system to rebuild. I haven't looked at Solidworks' ability to utilize multiple processors in a while. Have there been any new developments in that department over the past several months? I am talking about core solidworks, not FEA, rendering, etc.
Thanks for taking the time to look at this.
Paul
Paul,
My files are not close to what you need. Just some thought provokers for you.
What I would do since we have the machining and measuring capability in house. I would actually mill a sample part. Then I would take it over to the CMM and have the surface scanned. Then bring the scan data into SolidWorks and build off of that.
The models you uploaded in your original post in this thread take 10 seconds to rebuild after a Control-Q on my Core i7 machine.
I would hate to think how long you will be waiting for the pattern to resolve.
You need to find a way to get what you need without using the Sweep Cut with a Body. It is way to much of a resource hog for 768 pattern features.
Cheers,
Anna
Matt,
I don't know how to handle the corner radius on the tool. This tool is a tapered endmill with a small corner radius. As the corner radius sweeps up and down the arc, the is a geometry that I can reproduce with a fillet as far as I know. Variations of this profile as small as .0004in can be enough to cause a problem with the finished part. I would elaborate, but I can't without all the politaical crap.
After taking a close look at the tool body, do you think Solidworks can accurately model this part with surfaces?
Paul,
Can your milling machines and milling tools hold that profile to .0004 of accuracy?
Cheers,
Anna
Not without some care and a little luck. I think we can get there, but it won't be something that get's done without a lot of thought. The bottom line is that there can be a bit more deviation than .0004, but not a lot more. I need my model to be accurate becasue It is going to be used to produce electrodes that are going to be used to EDM a steel cavity which will be used to mold a plastic part. There are a lot of factors involved, and the sloppier I am upfront, the worse the end result will be. I also have to deal with plastic shrinkage, warpage, etc. Thankfully the tollerence issue takes place at each location on just this small feature, so the area involved is real small.
So, I would like to do this without error in the model. I'm not afraid that I will fail in the real world because I know what to do. Whether I can get it done with SolidWorks or not is another story. I am still somewhat new to SolidWorks, so it's very possible that it can be done. I still need to disect what Matt is saying.
If I can't do it in solidworks, I'll do it in another program, or have it done in another program. When I run into issues like this, I get discouraged fast. This is supposed to work judging by everything I've read, etc.
This is going to end up a challenge I think.
Paul,
Is this what you are looking for (see attached)? I modified the models, the path, and added reference planes. I was able to create a sweep with the tool using SW 2009 SP 4.0 (Win XP x64).
Regards,
Chris Thompson
Paul,
Now I understand what you are doing. Using the sinker EDM is what I would have thought you would want to do. I wasn't sure if you were thinking of hard milling directly into the mold cavity.
OK, since you are using a sinker, why do you need the shape you are tryng to mill in the solid model? The trode will be a male feature and will not be machined like you are trying to model your pocket.
Cheers,
Anna
I am modeling the plastic product which is a first step for us moldmakers. From the plastic part, I use mold tools to get to steel. From there, I seemingly go backwards to get to an electrode, but that's the way the workflow is in the mold industry. In fact, I don't personally deal with the electrode.
For what it's worth, I would be absolutely comfortable hard milling this female in steel on a high speed Makino milling machine. I would prefer it to EDM, but it's backwards from what I need.
Is there a way to sort these threads in a linear fashion instead of threaded? I am getting lost locating new posts.
Paul
Got it...see attached. It's quite possible that I needed the line tangent to the arc of the sweep path. It shouldn't have been needed, but at this point that's all I can think of except for the fact that my netbook is still running SP0.0.
If it turns out to be the tangent line that did it, credit goes to Chris. I saw that line as a major difference from my original part. In any case, it is working. I'll try to pinpoint it after I get some sleep.
Thanks everybody.
Paul
Paul,
Sweet..... :-)
I can see how adding the extra bits of tangent lines helps SolidWorks to determine its path better. Thanks for sharing the solution.
Also your successful attempt rebuilds in 4.21 seconds on my machine. Half the time of your original attempt.
I am going to try a big pattern and see how long it takes to pattern on my machine. Will post results in a bit.
Cheers,
Anna
Paul,
I created a block with a 40 x 40 pattern (1600 pockets) of the swept body feature. Verification on rebuild is toggled off and geometry pattern is toggled on.
It took 70.04 seconds for a control-q rebuild on my Core i7 machine.
The other big downside is the file is 107 MB with the pattern. Ouch!!!
The sldprt file can be downloaded from the following link
http://visualvault.auerprecision.com/ViewFile.aspx?DlID=465945c5-c441-4534-a6d4-6ef6679ba866
Cheers,
Anna
I came in to work so I could look at this now. I barely slept last night thinking about this.
The 40X40 Pattern rebuild at 70 seconds is super. Some of the parts I do here have rebuilds measured in quaters of hours. Most often I can work with the patterns supressed, but there is a stage at the end of design where ribwork is created that requires the full pattern. Those days are dreadful. Anybody out there designing microplates would understand.
Thanks so much Anna for taking the time to do all this. I am going to work on the shape to make it dimensionally accurate, as the example was just a test of the concept. I'll post the final shape if I get there today.
Paul
It's all over...
Seems that any small change to the sweep sketch and everything goes bad again. At least is does at work on SP3.0. I had success at home on SP0.0. I wonder if that is a coincidence. Now I have to go back home and mess around with this because I didn't bring my netbook with me. This is driving me crazy.
I should know better than to give this any more of my time because when things go like this, I am asking for trouble. If that shape (the working one) was dimensionally accurate, I could have continued on my design for days. Then the customer might request on slight change and BAM the whole thing falls apart. As a matter of fact, I am going to make that decision now. I will abandon the solid sweep.
Second time in two years that SolidWorks has left me stranded with things not working as they are intended. How can they say the software is capable of a solid sweep when I can't get a primitive shape to sweep through another primitive shape?
The sad part is that I have a perfectly valid concept for a design that I am going to have to abandon because it can't be modeled. I am going to hear about this for sure.
Thanks everybody for your help.
Paul McGarr
Seahorse Bioscience
I do not know if this is related, but I could not create a helical sweep using SW 2009 SP 3.0 on my 64-bit system (Win XP x64).I would receive the error message "Sweep operation failed to complete." and "Unable to offset one or more sketch entities.". When I updated to SP 4.0, it solved the problem and I was able to create the helical sweep. See this related post:
As a test, I sent the model (SP 3.0) to my SW VAR, and he created the helical sweep without problem using SP 3.0 on his 32-bit system. If I altered the sketch, or used Ctrl-Q for rebuild (without changing anything) the feature would fail and create the error message previous mentioned. Also, I had no problems creating sweeps using SP 2.0, so I suspect SP 3.0 was the problem, at least for 64-bit OS.
Try updating to SP 4.0 and see if it solves the problem. Is you OS 32-bit or 64-bit?
Regards,
Chris Thompson
www.appianwaytech.com
Paul,
I created the model in SW2009, SP4. So you may want to try updating to SP4 before you give up.
Cheers,
Anna
Upgraded to SP4.0. No difference. I wish I didn't have that taste of success. Once I change that "U" shaped sketch to anything other than a perfect half circle with two tangent, vertical lines, it goes south. Everything I tried, I made sure was a tangent path too.
An SR was submitted to SolidWorks by my VAR on my behalf. I will wait to see what they say about this, but I am not going to hold my breath.
I am seriously disappointed with this one. It's starting to be more than frusterating with this software. I's now becoming embarrasing and restricting to my creativity as a designer. Maybe I am asking too much from SolidWorks. I wouldn't think that was possible, but I am beginning to wonder...
Paul
Below is a snip from the "SolidWorks 2009 What's New" PDF file showing off the ability to do exactly what I am after. (Bottom right image) What they fail to mention is the tool needs to be exactly that form and the path needs to be exactly that shape. Change the tip of the tool to bull (flat with radius) from "spherical" and it will fail. Change the path to a "U" with tapered (and yes, tangent) sides and it will fail. Such a sensitive feature should not be displayed as "supported" as it has obviously not been tested, and is obviously not working.
I thought this was worth pointing out. I know I am beating a dead horse, but I'm just so frustrated. I am so tired of having things that are supposed to work, not work. It kills me to think of what we pay for maintenance, and to see where all of the money is spent. Focus needs to move to core functionality, and away from glitter and lights.
