Hi guys. I need to plot correct graph but i have problem to do animation and motion analysis for my final year project, parking system design. Please someone teach how to do the correct way. First, I try to put linear motor on the hydraulic cyclinder that attached to the arm, and after the platform pull up, then the i put another linear motor so it can pull futher until the platform is on the top of the frame. But the motion is wrong as when the first hydraulic being pull, the main arm which is supposed to go up, going down, pass through the floor. And the shaft also can also through the cyclinder. What is my mistake? I cant proceed to plot graph if my motion is wrong. I attach my file. Please, someone help to repair my mistake. Thanks!
SolidworksMotion Studies
do you need animation or do you need motion?
animation = just showing how something moves
motion = getting engineering results like velocity, acceleration, force..etc. out of your model.
i haven't had a chance to look at your model but for motion i would recommend simplifying the assembly down to only the parts that move at the assembly level and everything else be in subassemblies.
next, make sure you have your mates setup so that if you drag the assembly you can create the motion that you want. if you can't do that, motion won't be able to either.
then you can start your analysis.
Hi Jared, i want to do motion to get engenering result. I dont know wether my mate setup is all correct, but i can drag my assembly according to what i desire. And do i need to input motor for motion or just drag the assembly? And how to simplifiying down my assembly?
Motor is pretty standard.
Simplification is pretty standard. Remove parts you don't need, put others in sub assys.
