Help with modifying Macro, open part/assembly, set diametric, zoom to fit, set wireframe, rotate part, save as png
I am trying to modify a macro to complete a lengthy task on 3000 files. What I am trying to accomplish is to open a part or assembly( might use #task to batch)
set to diametric view, zoom to fit, set wire frame view, rotate part, force rebuild, then last is save as png.
I am getting a compile error right now with the codes I have put together.
I would appreciate any help getting this to work, I am definitely lacking training on API  SW2017 sp5
Here are my codes
Option Explicit
    Dim swApp                   As SldWorks.SldWorks
    Dim swModel                 As SldWorks.ModelDoc2
    Dim vConfNameArr            As Variant
    Dim sConfigName             As String
    Dim sPath                   As String
    Dim i                       As Long
    Dim bRebuild                As Boolean
    Dim bRet                    As Boolean
Sub Main()
    Set swApp = CreateObject("SldWorks.Application")
    Set swModel = swApp.ActiveDoc
    If swModel Is Nothing Then
    swApp.SendMsgToUser2 "Please open a PART file!", swMbWarning, swMbOk
    Exit Sub
    End If
   Set swModelView = swModel.ActiveView
   Part.ShowNamedView2 "*Dimetric", 9
   Part.ViewZoomtofit2
   swModel.ViewDisplayWireframe
   swModelView.RollBy (Degrees2Radians(-90))                                 ' Roll the model view by the specified angle
    bRebuild = swModel.ForceRebuild3(False)                                 'Rebuild the current part
    sPath = Left(swModel.GetPathName, InStrRev(swModel.GetPathName, "\\"))   'Get the path
    Next
End Sub
this is the module for rotating parts
Function Degrees2Radians(ByVal DegVal As Double) As Double
     Dim Pi As Double
     Pi = 3.14159265359
     Degrees2Radians = DegVal * 180 / Pi
SolidworksApi macros
